OPF sensors
Old Jan 1, 2021 | 04:51 PM
farisxx0's Avatar
GT63S 4door
Exclamation OPF sensors
hello all,
I want to install a downpipe on my GT63S . but it has a OPF sensor . my questions is
  • what is the function and the benefit of the OPF ?
  • can I install a downpipes with out OPF port or you recommend it with OPF port ?
  • is the downpipe of E63s 2019 same GT63s 2019 .
Old Jan 20, 2021 | 06:45 AM
farisxx0's Avatar
GT63S 4door
ANY ONE CAN HELP ..PLEASE!!
Old Jan 21, 2021 | 10:28 AM
NovaOne's Avatar
2021 CLA 250
These are questions the down-pipe seller should be able to answer for you. I am not trying to be flippant, but those guys are the experts. Perhaps the Renntech guys have some good information since they also sell a downpipe for the 63S.
Old Jan 30, 2021 | 10:40 PM
SilverBullet18's Avatar
C450,GLC 63,VW GTI
Otto particulate filter is like another catalyst downstream..and past the actual downpipe. it helps cleanup particulates even further for EU and other countries that require them.
no the e63 and the amg gt 63 downpipes are not the same the chassis differ in certain areas.
Old Jan 31, 2021 | 12:15 AM
superswiss's Avatar
2019 C63CS
The OPF as explained above is the particulate filter that's become mandatory in Europe and other places. It's not a catalyst, though. It traps fine particulates left over from the combustion. The sensor is there to determine when the filter is full, so the ECU can trigger a burn off cycle by increasing exhaust temperatures for a period of time and burn off all the trapped particulates. You will most likely get a CEL if you mess with it or try to remove it. The catalytic converters on the other hand don't trap particulates. They facilitate a chemical reaction to convert carbon monoxide and hydrocarbons (unburned fuel) to non-toxic CO2 and water.
Old Apr 22, 2024 | 09:09 AM
BenzNinja's Avatar
Former Vendor
if you really want this
best option is get a tune and ask them to remove
