AUX and ipod link
Old Apr 30, 2008 | 07:06 AM
frankh's Avatar
W204
AUX and ipod link
will I lose the AUX input if ipod link is installed?
Old Apr 30, 2008 | 08:17 AM
Hazemonster's Avatar
2008 C300
I have the ipod connection from the factory, and I ALSO have the AUX input. They both work....but I don't know what would happen if you had it installed after delivery. My guess is that your AUX input will still work.
Old Apr 30, 2008 | 09:26 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
i'd like to know the same thing.
funny thing is that here in France, the ipod can NOT be ordered directly
from the factory, but it's the garage that installs it.
Old Apr 30, 2008 | 04:49 PM
ancill's Avatar
Almost a Member!
C220 CDI Sport
I fitted the ipod module myself and confirm that you can have the Aux port as well as the ipod lead in the glovebox, the instructions with the kit suggest that you remove the Aux port from the glovebox casing and use the hole for the ipod lead, however, if you drill a hole to the same diameter next to the Aux port you can have both
Old May 1, 2008 | 02:43 PM
itcrashed's Avatar
MB w204 C300 Sport, Audi B7 A4 2.0TQ, Porsche Cayman 981
thats peculiar...i have factory installed ipod integration and i dont have an aux input - just the cable for the ipod in my glovebox.
Old May 1, 2008 | 03:58 PM
ancill's Avatar
Almost a Member!
C220 CDI Sport
itcrashed, you will probably find that if you remove the plastic cover between the door and glovebox you will find the aux port strapped up as the factory use the aux hole in the glovebox to introduce the ipod lead and rubber bung!
Old May 1, 2008 | 11:08 PM
w204_c300's Avatar
08 C300 Sport
I just popped off that panel and i do see the AUX wire sitting there. is there a way to run the wire out without having to drill a hole?
Old May 1, 2008 | 11:41 PM
itcrashed's Avatar
Ahhh - found it!
The hole you have to drill is rather large if you want to use the mounting hardware already attached to it...You might have to drill a hole that is about 2/3" in diameter to properly mount it. I may just drill a 1/8" hole and run a cable to it...dunno how much more it might degrade the signal though.
Old May 2, 2008 | 02:57 PM
yojason's Avatar
2008 C300W
Yo Ancill, how much did the iPod kit cost?
Old May 2, 2008 | 03:17 PM
ancill's Avatar
Almost a Member!
C220 CDI Sport
Yojason!! the ipod kit was £200 (Genuine Part) then the in-line amp was a further £20
Old May 2, 2008 | 03:21 PM
ancill's Avatar
Almost a Member!
C220 CDI Sport
W204 C300 the hole diameter is not so big and is into plastic that is not very thick, honestly you can't go wrong.........just make sure there is nothing in the glovebox before you start drilling
