SL55/63/65/R230 AMG: Drag setup and launch
Also, what are the electronics settings and launch technique do people use for best ET?
Thanks!
I get major wheel hop if i try it with esp on.
Cnterline might be able to dead hook from idle with good track prep and good drag radials, but i think he forgets other people are mere mortals sometimes :p
Haha ive never run anything but street tires on this car so far so i cant comment.
With the long gears, id expect you want shorter diameter tires for faster revs and wider for more traction.
So in the end wider is not always necessary when drag radials have a much softer compound and are design for a burnout to get sticky. They also don't come in a million different sizes so 265/40/18s become a popular fit event if you can fit something else wider. Getting an extra set of wheels for the tires is the easiest way to go. You will see the results are day and night difference when you can launch with no spin.
Look at the times some of the drag cars get out of a 10.5"/275 tire. It's plenty if you use it right.
Let me rephrase: shorter is better unless you run out of gear or cause problems with the ECU. Wider will provide more grip, but add weight. Typically you will want to run the shortest narrowest tires that can hold all your torque off the line for optimal launch. Unfortunately, im not sure what tire that is for the sl65.
That said, i think i will be switching from 295/30/19 to 285/30/19 if i can find a pilot super sport in that size. They werent available last time i bought tires.
Thanks for the info on the 18 inch wheels. I assumed brake calipers would be the limiting factor as far lighter wheels. The lightning community grinds down their rear calipers to run 15" bogarts, bajas, and racestars.
I run on a poorly prepped 1/8th mile track. Easing into the throttle than flooring it once it hooks is best, but hard to repeat. I spin a lot more than I want.
