Jacking up the W205 - Painting Calipers
Old 06-13-2016 | 03:05 AM
Kevo_Geiger's Avatar
2015 C300
Hello All,
I'm looking to paint my calipers with the G2 paint system and it requires the entire car to be off the ground so you can paint all calipers before the paint dries.
I have a hydraulic jack and some stands but I want to confirm that I do need a jack adapter (http://burgertuning.com/mercedes_ben...d_adapter.html).
How would you go about jacking the car up?
1) Jack the front of the car up from the center jack point (if there is one)
2) Place jack stands under each of the mounting point in the front of the car.
3) Jack the rear of the car up under the rear diff.
This would require buying two of the adapters....is there another way of doing this...besides taking it to a shop with an actual lift. I can't find any video's or pic to help explain the process.
Thanks in advance!
P.S. If anyone has a good walk-through of painting the calipers that would be great too. I've never done it before.
Old 06-13-2016 | 08:04 PM
jylee's Avatar
14 E350; 12 Camaro; 07 Range Rocer; 06 Dodge Ram
Even with a low profile jack, it may not have enough room to push under the car. I always place the jack under the jack point, and place the jack stand under the engine cross member and the rear shock. No need to buy jack pad, a piece of 2x4 for stability if required.
I suggest to remove the calipers off the cars, it make painting much easier. When ready, just change the brake fluid and bleed the brakes.
Old 06-14-2016 | 12:59 AM
604 C63's Avatar
2012 E550 Cabrio
You dont need a vehicle specific walk thru (theyre all very similar) so shouldnt be that hard to find. Ive had one in the past but cant find it. Sorry.
Ill say this though....any quality painting job has had quality prep. Take the brakes off the car, clean them, do it right. Do it right and theyll look like a million. Cut corners and itll look like crap. Guaranteed.
Old 06-14-2016 | 03:12 AM
Sahaj.c's Avatar
gallardo, c300, rover supercharged, cayenne S
i went through your hassle of painting my calipers. in regards to jacking, i jacked it up on four axle stands, behind each wheel. just need a jack, and four axle stands. no jack adapter. regarding the calipers, it is crucial you completely clean your calipers, no need to take them off. just simply cover the surrounding with newspaper and tape, and make sure u tape off certain parts of the brakes such as the rotors, etc. the prep work is 95%, the actual painting is the easy part. i used 5 coats per caliper, but one regret is that i did not clear coat my caliper for greater protection. reccomend you do so, but my smooth painting and prep work have left my brakes looking amazing, as they are 8 months old and have survived a canadian winter. will post pics.
Old 06-14-2016 | 06:19 AM
cenzo86's Avatar
2016 c450 / 2016 VW Jetta 1.8t / 2006 Wrangler X
The pics look great in the photo thread do you have any close ups of the rears though? They're the reason I haven't painted mine yet. I'm worried they're too plain looking to paint.
Old 06-14-2016 | 06:27 AM
Sahaj.c's Avatar
Although the rear calipers are small, the red suits them well. The front calipers look amazing when painted.
Old 06-29-2016 | 12:10 PM
danomite's Avatar
did you get over spray on the rotor? are you going to label it again? how long did it take you?
my project for the weekend!
Old 06-29-2016 | 07:23 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Personally I have have previously removerd the disck and pads when painting then masked off (when leaving callipers on the car, solely to eliminate the need for a calliper re-bleed).
Also do not underestimate the likelhood of overspray making its way on the surrounding vehicle underside and paint work.. it'll come off the paint with a clay but would be painful on the undrrside...
Old 07-03-2016 | 11:22 AM
Randyharris's Avatar
C250
As 604 63 said.
From what I understand, powdercoating is really the only way when it comes to painting calipers. Any other method seems to crack and get dull after a while. I saw this yellow camaro the other day and his calipers were painted yellow, the yellow that he used was a dull yellow compared to the bright yellow that is normally used and it did not look too good.
I will be painting the calipers on my wife's C250 in red (eventually) which should go well with the white car. Some people think powder coating is hard, its actually very easy and not expensive at all. The hardest part will be taking the calipers off the car and putting them back on, then bleeding the brake lines. Sure wish I had my quick jack already.
Old 07-04-2016 | 08:42 AM
danomite's Avatar
5 coats of color and 4 coats of clear over the stickers. looks good to me. also lots of sanding.
Attached Thumbnails Jacking up the W205 - Painting Calipers-image1.jpg   Jacking up the W205 - Painting Calipers-image2.jpg   Jacking up the W205 - Painting Calipers-image3.jpg   Jacking up the W205 - Painting Calipers-image4.jpg
Old 07-04-2016 | 11:15 AM
C250
Where do you guys get the stickers for the calipers? When I get ready to powdercoat my wife's car I want to get the mercedes sticker if available.
Old 07-04-2016 | 12:34 PM
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
Danomite, your calipers look great. Nothing beats putting in the time to do it right. However one small point, the AMG logo is not accurate. Compare it to the one on the wheel. The right hand leg of the "A" should be vertical - ie parallel to the left leg of the M. Unfortunately, it's a common problem with aftermarket AMG logos.
Of course, only MB nerds like us would notice.
Old 07-04-2016 | 12:35 PM
danomite's Avatar
got my stickers from ebay...like 5 dollars.
after painting them...don't think you need to spend the money on powdercoating! my brakes are soo smooth and glossy! 20 dollar mod! im more happy with how it looks!
Old 07-04-2016 | 12:38 PM
danomite's Avatar
I know! its the best I could find. didn't want to have nothing on it. we just wont tell anyone!
Old 07-04-2016 | 04:27 PM
vic viper's Avatar
S213
An MB nerd like you should know that there are several different styles of the AMG logo, the logo with the traditional letter "A" was replaced by the new logo with the vertical right leg around 2009
This has nothing to do with aftermarket parts.
Old 07-04-2016 | 04:29 PM
604 C63's Avatar
2012 E550 Cabrio
what VV said:
https://www.google.ca/search?q=amg+l...SLBasQ_AUIBigB
Old 07-04-2016 | 05:37 PM
danomite's Avatar
im happy with it...that's all that matters.
Old 07-04-2016 | 05:38 PM
604 C63's Avatar
2012 E550 Cabrio
You are spot on there.
Old 07-04-2016 | 05:39 PM
danomite's Avatar
side note.
I love your wheels Vic!!
Old 07-05-2016 | 07:40 AM
alexasa's Avatar
c
I've used G2 on the past, it's a fantastic product.
You mix in a reactive agent and paint it on. It auto levels, is glossy and smooth.
I would recommend and use again. I have no desire to paint the calipers on this car, however.
Any texture that existed before painting, will more or less exist after. The A4 I did these on basically had some boat anchor cast iron calipers that were textured (just keep in mind).
Old 07-05-2016 | 10:48 AM
danomite's Avatar
not if you sand a bit in between coats.
Old 07-05-2016 | 11:32 AM
danomite's Avatar
few more pics.
Attached Thumbnails Jacking up the W205 - Painting Calipers-13269258_10157093855005790_6609385849173037823_n.jpg   Jacking up the W205 - Painting Calipers-image1.jpg   Jacking up the W205 - Painting Calipers-image2.jpg   Jacking up the W205 - Painting Calipers-13432375_10157119361515790_4555393460691061314_n.jpg   Jacking up the W205 - Painting Calipers-image3.jpg
Old 07-05-2016 | 11:37 AM
vic viper's Avatar
S213
Get them proffesionally painted, looks better and is way more durable.
upload a gif
vinnypt (07-30-2016)
Old 07-05-2016 | 12:01 PM
alexasa's Avatar
c
looks like you didn't actually read my post.
Old 07-05-2016 | 12:40 PM
danomite's Avatar
I did. just a different way of doing it...is what im saying.
Quick Reply: Jacking up the W205 - Painting Calipers
