Crankshaft Pulley not lining up PLEASE HELP!
Old Oct 29, 2024 | 12:53 AM
Arlmeroc18's Avatar
2014 C300
I need help, the crankshaft pulley isnt lining up, and keeps falling off when testing, on top of that can still see the back of the pulley on the second picture, and fhe 3rd is of the new gasket, still a smidge out on the left side
Old Oct 29, 2024 | 07:04 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Oct 29, 2024 | 08:05 PM
JettaRed's Avatar
Veteran: Army
Is that an aftermarket pulley?
Old Oct 29, 2024 | 09:49 PM
Arlmeroc18's Avatar
2014 C300
Yes, it was, but we noticed no matter what it was not going to line up with the other pulleys due to extension, so we ordered OEM, the issue with that is that there is no special tool to install it or anything. Do you have any ideas?
Old Oct 29, 2024 | 10:55 PM
JettaRed's Avatar
Veteran: Army
There should be a notch in the center hole of the pulley. Normally, the woodruff key (#15) that sits in a cutout on the crankshaft is what aligns and holds the pulley (vibration damper) in place on the crankshaft. But without actually seeing how the pulley is attach, they may be some other alignment mechanism.
Old Oct 30, 2024 | 03:24 AM
Arlmeroc18's Avatar
2014 C300
So this is the original pulley, and going to need help finding a way to tighten it when I get the new one, and yes the notch i find and is easy to get in
Old Oct 30, 2024 | 06:08 AM
JettaRed's Avatar
Veteran: Army
Are you missing parts 30 and 35? Or just need help tightening it?
Old Oct 30, 2024 | 10:38 AM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
You typically have to remove the starter and install a flywheel locking tool to hold the crankshaft in place while you tighten the crankshaft pulley (vibration damper) bolt. Something like the following:
Old Oct 30, 2024 | 11:56 AM
JettaRed's Avatar
Veteran: Army
Careful. I believe the OP has an M276 engine. That tool may not work.
EDIT: Never mind. M276 is also listed for this item elsewhere.
Old Oct 30, 2024 | 12:04 PM
alynch's Avatar
Oops! Try this one:
Old Oct 30, 2024 | 01:14 PM
JettaRed's Avatar
Veteran: Army
They both cross-reference to 112589034000.
Old Oct 30, 2024 | 03:46 PM
Arlmeroc18's Avatar
2014 C300
Thank you! I'll give these a shot and let you guys know how it goes!
Old Oct 30, 2024 | 05:17 PM
Arlmeroc18's Avatar
2014 C300
How do I access the flywheel to insert tool?
Old Oct 30, 2024 | 06:09 PM
JettaRed's Avatar
Veteran: Army
Not sure. Here's the website. Maybe they can send instructions.
https://www.jtcautotools.com/product...-m112-jtc-4060
Old Oct 30, 2024 | 06:36 PM
alynch's Avatar
You can access the flywheel from a rubber plug on the bottom of the transmission bell housing (where you can also access the torque converter drain plug). Here is a YouTube video showing the location of the plug, plus a few additional methods to remove the crankshaft pulley:
Old Oct 30, 2024 | 07:53 PM
TimC300's Avatar
I thought the starter has to be removed for that tool? i could be wrong.
Old Oct 30, 2024 | 08:19 PM
alynch's Avatar
From the video, it looks like the toothed part of the tool is designed to fit through the hole, and the two pins on the end of the tool will fit in place of the two E bolts.
Old Oct 30, 2024 | 08:52 PM
TimC300's Avatar
I was thinking of my M272 TC and that access hole is straight up I think.
I dont even know how to remove my crankshaft pulley, its doesnt have the notches along the inside, instead it looks like a spoked wheel. id probably need a tool like this also.
Old Nov 4, 2024 | 06:02 PM
Arlmeroc18's Avatar
2014 C300
Yeah it looks nothing like this, I'll try and get you a picture
It is hold on post a picture
yeah it's difficult i had to risk it by using a crow bar, but its still uneven with the timing belt
Old Nov 4, 2024 | 06:10 PM
Arlmeroc18's Avatar
2014 C300
Flywheel is where that bolt is, hard to acess have gotten the toll it is too big, as you can see need something smaller
This is what it looks like when looking straight into it
Old Nov 5, 2024 | 12:59 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I’m coming in again on the back end of this, but I believe that you have to remove the starter to use that tool to lock the crankshaft like @TimC300 said. The two pins go into the starter bolt holes and the toothed part goes into the hole left by the starter and engages with the ring gear teeth.
Old Nov 5, 2024 | 05:21 AM
Arlmeroc18's Avatar
2014 C300
I see, well I tried looking for an easier way, spilled transmission oil everywhere and it was the transmission area thought it was something else, luckily I had to change that anyways, unluckily i didnt want to do that yet. Lol.
okay so where is the starter, is it on the left or right and how to remove it?
Old Nov 8, 2024 | 12:58 AM
Odd Piggy's Avatar
It’s been a few days so maybe you’ve already found it. On the M272 I think it’s on the right side held onto the bell housing by 2 eTorx bolts. Remove the battery ground connection before starting. I think the right hand exhaust pipe mounts have to be removed to get access.
Old Dec 30, 2025 | 04:23 AM
Arlmeroc18's Avatar
2014 C300
Apologies
Apologies for the late replies, been rebuilding this engine, so that wasnt the only thing, also can you share the website and program you guys use to figure out bolts and locations please?
lol the reason I got in this mess was because of that, im assuming the flywheel is the part that i keep missing, should be held to tighten bolt all the way right? Wanna make sure, not trying to break and take apart again.
thank you
