Anyone had luck buying OEM Xenon headlights for 2014 GLK?
Old Aug 9, 2015 | 11:40 PM
sblvro's Avatar
2020 C8, 2020 defender 110X, 2019 720S, 2014 GLK 350 4matic, 2015 escalade platinum, 2013 RRS HSELux
Can you turn it to airplane mode and see if it charges faster?
Old Aug 9, 2015 | 11:45 PM
Inyoury's Avatar
GLK350
We haven't tried that. I will see tomorrow.
Old Aug 10, 2015 | 01:52 AM
super7pilot's Avatar
2014 GLK250, 1983 Caterham super 7
Then your best bet would be to measure the voltage of the cigarette lighter socket with a multimeter. Or perhaps take the GLK back to the dealer and ask (demand) that they measure them. It could be as simple as a poor ground on that circuit. High resistance from an poor ground will cause a voltage drop. Which will most definitely cause the slow charging on your electric gizmos.
Old Feb 10, 2016 | 01:51 PM
sblvro's Avatar
Just an update. Somebody did it and the cutoff of the lighting looks just fine.
https://mbworld.org/forums/glk-class...-replicas.html
Old Jul 3, 2016 | 07:01 PM
  #30
Lottopop's Avatar
Glk
Did you changed the headlight?
Originally Posted by buckeyesoldier
I've been looking everywhere but can't seem to find a place that sells them? Do I have to go through my dealer? I want to replace my halogen lights for xenons but I don't want to do a retrofit. The only one's I found are from china 2013 2014 Year Benz GLK260 GLK300 LED Headlights D2H HID Xenon Projector Lens | eBay. The description says its for factory halogen cars but is this model they are selling the oem lighting package? Is this a scam? Hoping someone has experience with these or know where I can get a good price on some xenon headlights similar to the lighting package. many thanks!
ps: I know there are many threads on how to convert your headlights but I haven't found one with how to find oem lighting package or complete aftermarket headlight assembly for 2013-15 GLK 204.
Hello, I have same question as you, I was wondering if you have changed the headlamp,
Old Jul 5, 2016 | 07:47 AM
  #31
Mmr1's Avatar
2013 glk 350
How can those be Plug in Play, you need a separate ballast , and the yellow light around the top wouldn't be in the standard light plug - harness you have. I put in Phillips, 4300k, hid, I lowered the beam all the way down and don't blind oncoming traffic. I sometimes have an issue with the lights firing, Phillips said its the DRL I have on all the time, probably a relay was included in the factory set up. I don't see how those could be simply plug n play. My high beams are stock halogen. I'm happy with the conversion by Phillips.
Old Jul 5, 2016 | 10:36 AM
  #32
sblvro's Avatar
I think it's plug and play for non-HID headlights but those with regular halogens.
Old Jul 17, 2016 | 10:05 PM
  #33
Sharaf's Avatar
GLK 2010
Can you guide me on where did you get your Philip conversion ?
do they flicker ?
Old Jul 18, 2016 | 11:19 AM
  #34
Mmr1's Avatar
2013 glk 350
Philipsxenon.com
The only issue I've had is once in a while one or the other light doesn't light, it's related to having DRL on all the time , an added relay could probably fix it but I've lived with it, I just turn off the lights then back on. I then set the angle all the way down and still have great light.
Old Jul 18, 2016 | 11:23 AM
  #35
Mmr1's Avatar
2013 glk 350
Here is before and after, I am a pro photographer, I shot these manualy
so the actual brightness would be as real as possible
Old Jul 18, 2016 | 11:30 AM
  #36
Mmr1's Avatar
2013 glk 350
In the first dim photo, you can see how the lights were originally set completely horizontal, this not only blinds oncoming but you loose a lot of brightness by not having them shine down. First try aiming your lights so you can see the road better. I've seen how it's recommended to aim them at a wall so you know they are level, how stupid, a wall isn't the open road! Yes they really are as bright as the second photo, the right bulb wasn't set all the way down in this photo, it is now. Now I can see the pot holes!
Old Jul 23, 2016 | 03:41 PM
  #37
mjhawkins2346's Avatar
2016 GLE300d 4Matic
Have you had this tested by a lighting alignment shop? It looks like you have the very problem Sterns was talking about with "hot" local light and poor beam dispersion into the distance. I think you're the closest I've seen yet but I'm not sure this would work for me. Not enough "throw".
Old Jul 23, 2016 | 04:58 PM
  #38
Mmr1's Avatar
2013 glk 350
A " lighting alignment shop" ok, I don't think they exist. Actually your best "shop" is the road, or a parking lot. The beam pattern is great, not to hot anywhere. I'm in Chicago, probably the pot hole Capitol of the world. I can see the pot holes now! On the highway or dark roads, it's great. These Hid have 300% more output than factory halogens. You have to aim them down to not blind people.
Old Dec 10, 2016 | 01:09 PM
  #39
tigerdog's Avatar
GLK250
While E-code lamps have a different cutoff pattern than DOT approved ones, the aiming guidelines at on the Daniel Stern site are clear, well-written and easy to follow. I am not convince LED or HID conversions can be successfully retrofitted to reflector housings. The best reflector headlamps use the halogen filament as a known line-source that emits light omnidirectionally. The reflectors and lenses are engineered to precisely locate this light. An LED is a unidirectional point source, so even if it's in the same physical location, it will not be properly reflected and beamed forward. I could see how an LED might be tweaked with a surface-mounted prism to mimic a filament's output pattern but I've never seen an LED "bulb" that has such a thing. Has anyone else?
Old Mar 1, 2023 | 04:29 PM
  #40
Petya's Avatar
250 GLK
I have changed mine. The light came from From: MB Part Source support@mbpartsource.com
Part Number Part Name Price Quantity Part # 204-820-27-39 OEM Xenon Composite Assembly $688.20 Made In Austria.
Plug and play (sort of)! It had to be adopted to the car in order to work properly. Dealer will do it for $200, or a mechanic for a $100.
Old Mar 1, 2023 | 06:01 PM
  #41
habbyguy's Avatar
2011 GLK 350 4Matic
Since this long-dead thread was just resurrected, I thought I'd chime in. Yesterday, I mounted a set of Cougar Motor Flagship H7 LED "bulbs" that worked out very well (much better color, and a light output incease of at least 60%).
As usual, I did a quick (no narration) video showing the process.
Turns out my right headlight is aftermarket, and uses a different kind of clip to hold the bulb in - that had me scratching my head until I figured out that the "base plate" on the LED bulbs pulls off and can be mounted and clipped into place, and the "bulb" added later (by simply pushing it straight into the base plate).
All in all, I'm pretty impressed, and the cost was pretty reasonable (under $60 a pair).
Old Apr 12, 2023 | 05:17 PM
  #42
Adrien_907's Avatar
GLK 350
What did you have to do in order to "adopt" it?
Old Jun 3, 2023 | 12:48 PM
  #43
Mbtonya's Avatar
glk 350 4matic
glk 350 2010 upgrade headlights
i have a question that has not been posed to the forum. i see a lot of headlights for glk 350 2012 and up but does not include 2010 and 2011. what are the differences between these lights, and can I install a 2013-2015 headlight assembly in my 2010 glk 350?
Old Jun 3, 2023 | 01:37 PM
  #44
habbyguy's Avatar
2011 GLK 350 4Matic
Nope. Here's why (the differences are subtle, but obviously they're not interchangeable)...
Old Jun 3, 2023 | 02:18 PM
  #45
Mbtonya's Avatar
glk 350 4matic
alot of headlights sold have listing for fit from 2008-2015. is this a mistake. and what are the subtle differences besides the look of the interior of the assembly?
Old Jun 3, 2023 | 02:33 PM
  #46
habbyguy's Avatar
2011 GLK 350 4Matic
Look at the shape of the headlights - they're different, and won't fit in the "wrong model" bodywork. Any other differences are moot as a result...
Old Dec 9, 2023 | 02:43 AM
  #47
Merciful's Avatar
GLK350 2011 RWD
​​​​​​I see you installed them as a low-beam, do you think they will work as a high-beam too since the size is the same (H7)?
Is the mounting of Cougars will work for high-beam?
Old Dec 9, 2023 | 10:40 AM
  #48
habbyguy's Avatar
2011 GLK 350 4Matic
Yes, they should work well. The LED element is in the same alignment as the halogen bulb's filament so the focus should be fine. The bulb (misnomer, but oh well) is the same from the mounting bracket forward. It's a lot bigger behind that, but there's plenty of room in the housing for that, and for the supplied resistor.
