Part numbers for Exhaust Clamps and Seals
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
I am about to install Mikes Power Pipe, but being in the NorthEast, everything is pretty rusty and frozen, so going to probably need to cut them off, but either way want to get the clamps and gaskets.
Online diagram of exhaust parts seems to conveniently leave out only the clamps and gaskets for some reason.
Up on the lift, I got the following part numbers for the clamps.
Clamps part numbers are:
A0004901441 Behind Cat Drivers Side
A0004901541 Behind Cat Passenger Side
A0004901441 In Front of Cat to Header Pipe
A2214920081 is Cat Converter Left Sealing Ring, Looks like only the clamp that ends in 1541 uses a seal, the other 2 just metal on metal.
Just wanted to document as I could not find the info easily searching around.
Found this parts diagram eventually on an italian site that seems to list them parts.
http://www.iauto.lt/mercedes-benz/Ca...oups_ID=529173
Rob
Rob
I found with rusty clamps on mine all I had to do was give them a good twist and the bolts snapped in two making it easy to get the clamps off. You will need new ones as the nut is a barrel shape and I don't think you will find one off the shelf. Nice SS clamps but nuts and bolts that rust together, go figure. GL with the install.
FCPEuro (11-08-2016)
Thanks for giving us a shot, also if you guys need diagrams you can use our diagram site oempartsindex.com
We also have a banner that pops up after you enter your Mercedes, the site is a work in progress but should be helpful.
Rob
