GET RID OF ABC keeping the pump
Old 01-10-2017, 12:25 PM
member
pmercury's Avatar
CL
Lightbulb GET RID OF ABC keeping the pump
Verry simple
1) remove the Y36/1 and 14 block
behind this block after removal you will see a connection block (B)
two inputs, next to each other, one output going to the front of the car into bumper
2) REMOVE block B. cut the plug of the metal tube going to the bumper
3) connect your hose there
3 REMOVE 52a - 52 (see A)
you'll see two hoses next to each other with aluminum foil, FORGET THOSE
4) Cut the plug of the black hose (that is the one coming from the pump)
connect the other end of your hose connected in B
all done ! perfect circuit, reservoir to pump to cooler to reservoir
NEW! YOU CAN DELETE THE ABC RADIATOR. has been tested for over a year now
If you use the dash light fix module, you can disconnect all electrical wires to ALL the ABC devices
Read my posts before you go into the wrong direction with DAS / Xentry Diagnostics
__________________________________________________ ___________________________
Want to talk live ? Please install Skype and hit the little S (skype button) under my Username or just PM me
smicsk (09-06-2023)
Old 01-11-2017, 04:55 AM
member
pmercury's Avatar
CL
IMPORTANT NOTE
there is a hose ABC DAMPER HOSE going nowhere in the front of the radiator
as I didn't find out yet where that is connected, you should leave it in place
you can remove everything else starting from the front wheels to the back and disconnect ANY sensor if you have a Dashlight Fix Module from stutmasters
I also recommend to disconnect the connector on the suction valve on the pump.
Old 01-11-2017, 05:00 AM
renault12ts's Avatar
W215 CL500 2005
I presume this just circulates the fluid...with no pressure in the system? So, no (or little) chance of a burst pipe?
Old 01-11-2017, 07:08 AM
member
pmercury's Avatar
CL
yes exactly !
no pressure
pump runs like charm, no noise, no oil spilling when engine is stopped, I feel like I removed cancer from the car
no voltage on the suction valve on the pump = valve closed = very low pressure
Old 01-31-2017, 01:53 PM
Ste73's Avatar
Mercedes cl500 2000
I just fitted a w220 power steering pump. Very easy.
Old 02-01-2017, 12:32 PM
W215 CL500 2005
It would be appreciated if you could do a write up about your install...especially if you took any photos.
The following 2 users liked this post by renault12ts:
2MERKS (06-01-2021), Dadzcad (09-12-2021)
Old 02-03-2017, 12:05 PM
member
pmercury's Avatar
CL
I have a CL600 V12 twinturbo
W220 pump has not been verfied on cl600+ yet
Old 02-04-2017, 03:27 AM
Ste73's Avatar
Mercedes cl500 2000
Sorry didn't realise you had v12.
Old 02-04-2017, 06:32 AM
member
pmercury's Avatar
CL
Thumbs up
don't worry
it's just that that pump might not fit on V12's
Old 09-06-2017, 05:38 AM
stuartph's Avatar
Cl600 TT
Hi
I have some questions about this
The pipe going to 52a is the pump output?
How did you remove the ABC radiator and link the pipe work
The pipe on top of the ABC reservoir is this totally removed when you remove ABC radiator
Did you use 10mm hydraulic hose?
Old 09-06-2017, 02:16 PM
member
pmercury's Avatar
CL
Originally Posted by stuartph
Hi
my final work was that I cut everything off
just leave the reservoir and pump (1) and (2)
cut the line from pump to 52a
connect that to the top of reservoir.
cut off everything and trash it
everything
insulate the wires you disconnect from devices
that's all
The following 4 users liked this post by pmercury:
Robert Heard (03-30-2020), smartadze (09-20-2017), stuartph (09-07-2017), wspen711 (01-28-2018)
Old 09-07-2017, 09:09 AM
stuartph's Avatar
Cl600 TT
Thank you pmercury
Does that include the removal of the dead end pipe work from the pump (banjo fitting) and the pipe coming out the bottom of the resivour near the 2 in diagram
Old 09-07-2017, 02:15 PM
member
pmercury's Avatar
CL
Thank you pmercury
just do this, then remove everything
I suggest you cut all pipes as removal is easier
remove all devices and radiator
and don't be afraid about pressure, there is no more. keep tank filled as usual, if not you'll kill your pump
The following 3 users liked this post by pmercury:
Odai Attal (05-29-2021), smartadze (09-20-2017), stuartph (09-07-2017)
Old 09-07-2017, 03:44 PM
stuartph's Avatar
Cl600 TT
Ok will do and thanks
Old 09-09-2017, 11:00 AM
smartadze's Avatar
2003 CL-500
Great information! Getting ready to install my YellowSpeed kit.
Question: what is the best way to get rid of warning messages and etc but NOT using the $400 Strutmasters box?
If doing the short-circuit piping suggested above - but not yet removing everything ABC - what components must be disconnected other than capping off the lines at the struts?
Old 09-10-2017, 04:56 PM
member
pmercury's Avatar
CL
strutmasters have a video online to explain what to do if you don't want to remove all components
for dash message elimination you need XENTRY DAS developer and code out ABC
smartadze (09-10-2017)
Old 09-10-2017, 05:35 PM
smartadze's Avatar
2003 CL-500
I can find no such video on the Strutmasters site. They do show how to wire the stop module, but other than capping the lines, nothing about what to do if you don't remove all the ABC components.
Thanks.
Old 09-10-2017, 07:00 PM
member
pmercury's Avatar
CL
Thanks.
bikebuff (08-22-2018)
Old 09-10-2017, 07:39 PM
tusabes's Avatar
Mercedes
If you pull the abc fuse you'll get the white error message instead of the red one
the white error message can be turned off by pressing on reset button on the right side of instrument cluster. You just have to press the reset button each time you get in the car
The following 4 users liked this post by tusabes:
HopefullyE63 (11-28-2019), ooobex (06-04-2019), sharp41248 (03-18-2020), smartadze (09-11-2017)
Old 09-11-2017, 09:59 AM
smartadze's Avatar
2003 CL-500
[QUOTE=pmercury;7261002]
Thank you, but those are just the installation videos. Other than simply capping the lines, there's nothing regarding other ABC components, error messages etc.
Appreciate the input though :-)
Old 09-12-2017, 10:59 AM
W215 CL500 2005
[QUOTE=smartadze;7261288]
The error message will remain unless you buy the Strutmaster module.
As for removing all the abc bits etc just go at it with a few wrenches and sockets once you have created a loop back to the pump...or change the pump for one from an S500 with airmatic.
Old 09-12-2017, 08:41 PM
ruflife1's Avatar
2008 S63, 2012 E550, 2005 E55, 2005 SL55, 2013 SL63, 2020 AMG GT, 1994, 1998, 1999, 2001 SL500
Module
[QUOTE=renault12ts;7262079]
Has anyone just bought the module alone? I thought Strutmasters would only sell it to those who have already purchased their kit
Old 09-22-2017, 03:04 PM
smartadze's Avatar
2003 CL-500
New method to loop ABC output
All kudos to PMercury - he showed us the way to loop the ABC pump output - at low pressure - and complete a YellowSpeed strut installation.
I have found an even easier method, one that doesn't even require one to get under the car :-) It assumes your tandem pump is still good (or passable), and uses existing plumbing so leaks aren't an issue. Plus it takes 15 minutes and costs about $4.
The downside: the ABC system is dead - but still there. This method wouldn't work for PMercury, as his objective was to remove the system completely. But for the rest of us, it is a simple and easy way to get the YellowSpeed conversion up and running with a minimum of trouble. We can wait to remove the other components at another time.
Note the overall system diagram: we are cutting into lines A and B and connecting them with 3/8" fuel line. We are removing Line C and plugging both ends. THAT's IT! You can plug the other (dead) cut lines if you like, but they have no pressure and mine didn't leak.
Pump output goes from pump to 52, then back to left wheel well.<br/>Line B is return line from rear, heading to cooler and reservoir again.
Here is what they look like in the left wheel well.
Here they are connected.
Find Line C in front of the left wheel well, near the headlight. Remove both ends of Line C. Cut off the line at the end of the metal part, and plug the line with a piece of 3/8 hose and some plugs and clamps. Re-install each end of (plugged) line C. You might be tempted to use a 3/8" flare plug: this will work for the no-pressure side, but will not seal the pressure end.
Location of Line C, right above the horn. This is the pressure side - the remaining line goes to the cooler and reservoir.
Line C
Cut off the fittings and plug each. Re-install.
Done!
You must remove Fuses F9 and F46, and remove the electrical connector at the ABC pump near the suction line on top. When you start, you are circulating through 52 and then right back to the cooler, filter, and reservoir. Pressure is low so leaks not a problem. By the way, borrow or buy a Sawzall and a metal-cutting blade: makes quick work of cutting the steel lines.
I can drive around like this forever on my YellowSpeeds, or contemplate the day I replace the tandem pump with a PS pump from a W220 and remove every last bit.
The following 3 users liked this post by smartadze:
HJAMES608 (11-11-2021), renault12ts (09-22-2017), smicsk (09-19-2023)
Old 12-02-2017, 01:05 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
i ran mine in a similar setup for a long time. I forget what exactly caused my ABC pump to fail entirely but eventually it wouldn't stop leaking/smoking/spitting out fluid. I ended up using an s430 p/s pump on my cl500/55 setup
Old 12-07-2017, 10:41 PM
Yi3o8's Avatar
2002 cl 55
My ABC red warning has been on and off for a while. Abc doesn't work but car drives fine. Do I need to install new struts or can I just do this mod to relieve pressure on the system?
Quick Reply: GET RID OF ABC keeping the pump
