Wheel Thread
Old 02-01-2017, 05:32 PM
  #51
SupremeChicago's Avatar
w212
19X8.5 all around
flipstah (02-01-2017)
Old 02-01-2017, 06:42 PM
  #52
flipstah's Avatar
2010 E550 4Matic
Originally Posted by blegthbloo
These were on my E350, but the fitment is the same on my E550 (just too lazy to go take pics of it)... although the 550 sits a little lower up front thanks to the extra weight.
That's nice.
Is it on lowering links?
Old 02-02-2017, 03:27 AM
  #53
Hsg08's Avatar
MB W212, MB W218, BMW F06, BMW F48
It's been posted but here's my DD again on 19's.
Old 02-02-2017, 08:24 AM
  #54
blegthbloo's Avatar
2013 E550 4Matic
Originally Posted by flipstah
That's nice.
Thanks! Vogtland springs.
Old 02-02-2017, 09:42 AM
  #55
Diesel #2's Avatar
2016 E 250 Bluetec
Old 02-02-2017, 04:35 PM
  #56
MBSebas87's Avatar
C300 Sport 4Matic
Originally Posted by Diesel #2
I love your setup!
Old 02-03-2017, 07:55 AM
  #57
Diesel #2's Avatar
2016 E 250 Bluetec
Originally Posted by MBSebas87
I love your setup!
Thanks pal ...
Old 02-03-2017, 08:05 AM
  #58
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
Bluetec, Have you considered de-badging? I did mine, it lowers the rear visual a bit more plus it looks wider and of course cleaner look. The blutec letters I found were flimsy and when I hand wash the lambswool would snag.
Old 02-03-2017, 08:20 AM
  #59
Diesel #2's Avatar
2016 E 250 Bluetec
Yeah i have been thinking about that actually because i want to take off the factory trunk spoiler and install a different one. And the guys told me its the same process to take off the badges and spoiler. So yeah i am going to take everything off except the Mercedez emblem. I am also going back and forth about wrapping the chrome trim around the windows in a gloss black chrome effect. Along with the front grille and the chrome piece under the front bumper. Do you have any photos of ho yours looks ?
Old 02-03-2017, 02:53 PM
  #60
SEC1939's Avatar
hair dryer dental floss and some paint cleaner like PS2 20 min all done. I was quite happy with my results. Looks even better 3 months after. In the EU badge delete is an option at order time.
Old 02-03-2017, 03:43 PM
  #61
flipstah's Avatar
2010 E550 4Matic
There are many adhesive removers available to clean up residue, but the key is definitely hair dryer + dental floss.
Old 02-03-2017, 03:49 PM
  #62
chipmjohnson's Avatar
2013 E350 Bluetec, 2007 Corvette supercharged, Saab 9-5, Hyundai Genesis Sedan
A slightly different approach to the w212
Old 02-03-2017, 05:07 PM
  #63
SEC1939's Avatar
yes I forgot I did use goof off or something like it
Old 02-03-2017, 06:06 PM
  #64
Jabberwock's Avatar
Eclass
Thanks pal ...
what are you wheel sizes?
Old 02-03-2017, 06:08 PM
  #65
belarus27's Avatar
2010 e550 p2
are those w211 wheels?
and yes goo gone , goof off removers will be fine.
Old 02-05-2017, 12:41 PM
  #66
Diesel #2's Avatar
2016 E 250 Bluetec
Fronts: 19x8.5 w. 235/40 tires
Rears: 19x9.5 w. 265/35 tires
Old 02-07-2017, 06:38 PM
  #67
RS4Life's Avatar
2008 Audi RS4 Cabriolet
Great set-up, agreed. Can i ask what spacers your running, if you are? i've got a stock E550 2011 4-matic. if i keep the 245/18's and don't lower, do you know what spacer mm is gonna push the tires in line with the fenders? i've seen guys using 15's, 20's...and staggered. but i think mine is squared anyway. thanks!
Old 02-07-2017, 09:39 PM
  #68
Diesel #2's Avatar
2016 E 250 Bluetec
I am not using spacers, the wheels are custom made for w212 and fit perfectly without any accommodations. Original 245/18s are 18x8 all around. So in order to make the rears sit flush with the fender you would have to use a 1 1/2 inch or 38mm spacer. And you would need a 25mm spacer to make the front sits flush.
What i would do if i were you since you want to use your factory wheels and are not planning to lower it, i would use like a 10-15 mm spacer and use wider and taller tires and it will fill up the gap. Just stay below 26.5" diameter on tires and you will not have problems. I'm running 26.4" tires and lowered and i don't rub.
RS4Life (02-10-2017)
Old 02-09-2017, 02:18 PM
  #69
BlownS4's Avatar
2015 E63 - Current, 2012 E550 - Current, 2019 Audi Q7 3.0T - current
19x8.5 35offset 245/35/19 19x9.5 40offset 285/30/19
Brand is UPWheels but I'm probably going to sell and get the Vertini RF1.1's like Diesel since they are rotary forged.
Old 02-09-2017, 02:40 PM
  #70
BBB78's Avatar
W212
Rotary forged is another way of saying "cast"
  #71
belarus27's Avatar
2010 e550 p2
i have staggered stock amg wheels
and recently installed rear spacers..i went with 15mm , should of used 20mm. still looks much better. rear ones 265/18
but if all you tires are 245/18s then you can do 10mm front (im sure 15mm would be pretty flush so it might scrape ) in this case 10 is safer.
and because of 4matic im not sure if it has to be 10mm also in the rear or you can actaully go wider.... like 15 or 20.
but with 10mm all around u be safe.
Old 02-09-2017, 02:57 PM
  #72
BlownS4's Avatar
so you feel they are just as soft as regular "cast" wheels?
Old 02-09-2017, 03:02 PM
  #73
BBB78's Avatar
W212
Of course. It's just a spun CAST mold at the end of the day.
Old 02-09-2017, 03:17 PM
  #74
BlownS4's Avatar
so all this crap about the metallurgy changes and the wheel becomes stronger from all the different companies you think is BS?
Old 02-09-2017, 03:18 PM
  #75
Diesel #2's Avatar
2016 E 250 Bluetec
Is that what the HRE rep told you BBB ? Lol just kidding. The process is actually totally different and wheels are stronger and lightweight than cast wheels.
A cast would mean you take a mold and pour molten metal into it, in rotary forged they take maybe a 6 inch piece of super strong material and spin it under heat to form the design they want. Very different process than casting like Vossens or replica AMGs
Quick Reply: Wheel Thread
