C63/C63S AMG
Rear Diffuser removal/Install
Old May 14, 2017 | 07:23 PM
bgm130's Avatar
2016 C63S
So I received my Modecarbon Front Grill and Rear diffusor on Sat and since I don't have the patience to wait to have them installed I went looking for a guide online which I could not find for the w205. After spending some time under the car and looking at the new piece's mounting tabs and holes I figured it out. so here is a step by step guide in case you want to try it on your own.
Tools needed. Torx bit T30, Drill and 1/8" drill bit, set of plastic panel removal tools (not necessary but helpful)
going to write steps but have added pictures on each part
Step one: on each side you will find 2 T30 torx screws holding the exhaust tips in place. unscrews those and put them and the white plastic retainers they go into to the side.
Step 2: now that the tips are free you can push in towards the front of the car to free the tabs on the top of the tips(pay close attention to how those tabs are seated, its imperative that they go back exactly). then you can pull them out and put to the side. (I have a separate write up for these when I installed the Awe tips)
Step 3: Drill out the 4 rivets, two on each corner and 2 towards the center.
Step 4: Start on one side close to where the outside rivet was and start to pull the black away from the painted part. there are tabs every few inches but with a little bit of force they pop out one at a time.
Step 5: once these are all popped out you can putt it away enough to look inside and see there are 8 tabs. at this time you should also be able to see the reverse sensor wires and unclip them at this time. also you can unlip the wires in a few spot that are attached to the diffuser.
step 6: The 8 tabs mentioned above. I used my trim removal tools to pry and at the same time unlatch these. I have taken a picture of how I used the tools to do each one
Step 6: once you got the last tab the whole thing should just unfold down away from the car.
Step 7: at this point you have 2 options. you can separate the two parts of the diffuser or you can snip off the two rivets holding the whole assembly. I snipped the rivets since that parts seemed pointless and figure it could cause rattles and served no purpose anymore.
Step 8: at this point you should have what I show in picture below. at this time its best to reinstall the exhaust tips with the 4 Torx screws and white retainers. Make sure tabs are back in place properly.
Step 8: Now its time to install the new piece. Start with the tabs on the outside edge where the rivets go. press the tabs along the top into their slots. once everything is seated properly you can re rivet the 4 spot and you are done.
Old May 16, 2017 | 11:46 AM
longbow0404's Avatar
2019 E63s
Great info; I'm getting a custom Diffuser made and this will help me in removing the stock one
Old May 16, 2017 | 02:37 PM
MFahrer's Avatar
C63s AMG (looking to buy and do Euro Delivery)
Thanks for the info!
Any pictures of the installed rear diffuser yet?
Old May 22, 2017 | 06:33 PM
bgm130's Avatar
2016 C63S
Sorry missed this
Looks great with the exhaust tips. Still trying to get a picture that does it justice. It looks great in person
Old May 22, 2017 | 10:44 PM
fresnobrianb's Avatar
2005 C230
Originally Posted by bgm130
Sorry missed this
Did you do the grill too?
Old May 22, 2017 | 11:14 PM
bgm130's Avatar
2016 C63S
Yes I did that one myself as well.
Old May 23, 2017 | 10:55 AM
2005 C230
Pretty straightforward? Any tips?
Old May 23, 2017 | 11:48 AM
bgm130's Avatar
2016 C63S
that one is tough. and i ended up breaking a few of the tabs on the stock one. the star comes out by twisting it counter clockwise and then you can access 4 of the tabs that hold that section in place. After that ir was just getting my arms far enough in to access the farthest side and undoing one tab at a time while you pull forward. as i pulled i stuck a rag between it and the grill to keep it from re attaching itself. Other then that it was just playing around with it.
the install was just lining it up and pushing in. The fit was right on for so everything slid into place. the only issue i had was the bottom outside edges. you will see a narrow tab with a hole in it. that area seemed to not want to stay in place. that was fixed by butting a short screw through that hole and it snugged it up nicely. ill see if i can get a picture when i run out for lunch
Old May 23, 2017 | 12:46 PM
Vassago's Avatar
2017 C63s Coupe
@bmg130 I understand for your new rear diffuser you probably had to remove the whole stock diffuser, but could you have just removed the bottom part with the fins instead of the whole thing? I ask cause it looks like the edition 1 diffuser utilizes the top part and 2 new lower sections are added.
Old May 23, 2017 | 01:39 PM
Mikey_boy's Avatar
2017 C63s Sedan | 2016 Yukon XL Denali
How did the cover to the tow hook go for you? Mine doesn't quite line up
Old May 23, 2017 | 02:34 PM
bgm130's Avatar
2016 C63S
No the stock unit is one large piece. The aftermarkets ones like PSM or RW carbon (GTX version) must install over the stock piece. Only part you can remove is the silver 3 piece trim. other then that it is solid.
It pretty close to perfect. in the picture above i had actually left the carbon piece at the shop so at that point the stock black part was just wrapped in 3m carbon fiber wrap. that is why it looks a bit off there
Old Jul 18, 2017 | 02:57 PM
PL27's Avatar
x
Bump
Old Jul 19, 2017 | 01:03 PM
Vassago's Avatar
2017 C63s Coupe
Installed the Edition 1 rear diffuser, very easy.
Old Jul 30, 2019 | 02:34 AM
sentralfyr's Avatar
2015 S205 AMG
First of all, Thanks to bgm130
Here is my install on S205 All Black
Old Nov 28, 2019 | 12:26 PM
shan16's Avatar
C250
For some reason I cannot get the top middle clips to lock into the bumper bar and tricks?? 4 or 5 clips on top won't lock in
Old Mar 19, 2020 | 10:07 PM
TLDream's Avatar
a UFO
i have popped the top clips off from the bumper, but I don’t understand where are the 8 clips you are showing. Do I look from top down to find them through the gap between the top clips and the bumper? Or do I find them under the car looking up?
I see 7 lines in your picture, where is the 8th?
From top down which way do I push to unhook?
never mind, got it off
Old Sep 3, 2020 | 01:20 AM
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Just wanted to thank the OP for this write up, installed my mode carbon diffuser tonight and this thread made it a ton easier!
Old May 8, 2023 | 12:26 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
For those of you who have installed an aftermarket carbon fiber diffuser, how did you affix the parking sensors to it? I finally got around to installing one that I picked up a while back and while the parking sensor holes are in the new diffuser, there are no provisions on it to attach them. My first attempt at securing them with some RTV gasket maker that I had in the garage was unsuccessful. I have now removed the brackets from the stock bumper and JB welded them to the CF diffuser, but I am not sure that it is going to work out since the sensors are not flush in the hole as the profile of the OEM bracket does not match the contour of the CF diffuser. I even inverted the brackets and switched their sides (passenger side to the driver's side, and vice versa) which helped, but is not perfect. My concern is that this will cause the parking sensors to encounter interference from the diffuser itself.
Any tips/tricks would be greatly appreciated.
Old May 10, 2023 | 12:09 AM
miamiboy's Avatar
C63s Sedan
my RWCarbon diffuser didnt come with proper slots for the sensors so I plugged them in, placed it on something off the ground, superglued them into the diffuser and carefully attached the diffuser to the bumper.
Old May 15, 2023 | 01:22 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
I want to thank the OP for the write up, it was very helpful. For anyone wanting to do this in the future, I figured I'd add a couple helpful pointers.
Once you get the stock diffuser unclipped from the perimeter clips, it'll still be attached by some internal clips that the OP marked with the 7 red markings on his picture. You get at them by pulling the stock piece out and you'll see the clips from the top. Use a wide, pronged trim removal tool and rock it from left to right or right to left. They'll come right off.
Next, the carbon fiber diffuser did not have a way to affix the parking sensors. It only has holes cutout. I removed the clips for the parking sensors from the stock diffuser and inverted them and switched their sides so the electrical connector would still point where it needed to in order to plug it in. I used some JB Weld to attach them to the diffuser. Makes the piece removable if I ever need to and the parking sensors work fine with no interference.
Old Feb 4, 2024 | 11:22 PM
jonlop11's Avatar
bmw
Help
how did you put back all the sensors to the bracket ? My carbon diffuser has nothing they held the middle part
Old May 18, 2026 | 04:04 AM
Thank you for the additional insight! Installed an OEM carbon diffuser today and this made it so much easier than pulling off/reattaching that whole bracket type thing!
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
