Old 05-12-2017, 03:51 PM
  #276
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Yeah those radiators took me three days to make. Didn't think it was gonna take me that long but once I started I had to finish them.
No I'm not going to put G63 badge on the back. I'll stick with G500.
Trying to get a hold of the sound deadening sales guy to purchase the product but haven't been able to get a reply from him.
Old 05-12-2017, 05:56 PM
  #277
Done and done )
Old 05-13-2017, 10:14 PM
  #278
Took apart aftermarket facelift mirrors. Strange that lots of people install them but no one talks about how to take them apart to be painted . From what I see these "might be" assembled a little different then OEM. But after fiddling with them I was able to take them apart.
First remove glass by gently pulling out on it.
Then remove one small black screw towards the bottom.
Gently pry up on the back of the cover where it's clipped on ( two clips I marked with white tape ) .
There is a third clip from the front in the corner.
While you have all three clips pulled back, you then wiggle the cover up and it should come off.
I think I will be painting the black parts as well, so therefore I remove the bottom black cover by unscrewing two more screws from the inside and wiggling it down.
Old 05-13-2017, 11:43 PM
  #279
sterz85's Avatar
w205 C43, 958.1 CTT
does the blind spot light connect to anything?
i wondered if one could add on the aftermarket blind spot detection system and integrate it with the updated mirrors that have the warning triangle
Old 05-14-2017, 12:23 AM
  #280
Yes the blind spot triangle is functional, I actually checked it myself and it lights up. I also would like to look into aftermarket blind spot monitoring sensors to see if I can get them to work with the mirrors.
These mirrors also have power folding ability, which I also confirmed.
sterz85 (05-14-2017)
Old 05-14-2017, 11:24 AM
  #281
sterz85's Avatar
w205 C43, 958.1 CTT
if you don't mind, could you share where you guys the mirrors from?
thanks!
Old 05-14-2017, 11:31 AM
  #282
I bought them couple years ago, I don't recall from whom, but they are the same ones like you see for sale on eBay.
Old 05-14-2017, 12:34 PM
  #283
RA050524's Avatar
g500
yeah i kinda just gave the body shop my mirrors and they taped everything except the covers and just sprayed them.
But its odd because when i installed the mirrors, the passenger side mirror's LED doesn't work. i even checked the wiring and everything seems fine.
Old 05-14-2017, 12:38 PM
  #284
Yeah I think that's what most people do but it's not the same. I wanted to make sure that it's painted all the way around in all the crevices.
Old 05-18-2017, 12:59 AM
  #285
Purchased BLIND SPOT ASSIST from eBay. Will try to install it and get it to work with the mirrors.
The following 2 users liked this post by Kobzarhomes:
grane (06-07-2017), sterz85 (05-19-2017)
Old 05-19-2017, 12:13 AM
  #286
sterz85's Avatar
w205 C43, 958.1 CTT
Awesome! Please take pictures of the install/wiring
Old 05-20-2017, 09:22 PM
  #287
BonitaBeast's Avatar
2008 G55k
Great to see the work and dedication that has gone into this project!
I'm a bit late in subscribing, but..... Subscribed!
Great thread
Old 05-20-2017, 10:34 PM
  #288
Thank you
Last few days I have been sanding the hell out of the car, preparing it for paint towards the end of next week. Alot of sanding when you are re-spraying the entire vehicle. Doors, fenders, bumpers, etc... are coming off, hinges will be painted separately. Making sure every little crack is sanded so there's no glossy paint anywhere on the car. My fingers are killing me but it's almost ready.
Old 05-21-2017, 06:39 AM
  #289
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, C43 AMG Cab
Thank you
Are you planning on shooting it yourself? If not a professional shop will probably prime it and block it to be sure there are no panel imperfections. Looks like you are making good progress. Once it is painted the reconstruction details begin. In my experience this is a more tedious part of the build but very satisfying because you begin to see the final product with each completed step. Good luck moving forward.
Old 05-21-2017, 10:42 AM
  #290
No, i'm not painting it myself.
Shop will put sealer down and then paint. They will not be priming or blocking it. When it arrives at the paint shop, it will be ready for them to start spraying.
Im going over everything with 600 grid and then 800 grid.
Old 05-22-2017, 12:07 AM
  #291
Took doors off, still sanding.
Almost ready for paint.
Old 05-25-2017, 12:44 AM
  #292
Both fenders and hood are going to get raptor treatment on the inside. Taped everything around the edges so there's no overspray on the exterior surface. I'll post pictures of the finished product tomorrow.
Old 05-25-2017, 01:32 AM
  #293
just1time's Avatar
s550
Aren't you worried about the age of the car. Would be sad to do all this and then have engine or tranny fail. Or are you planning on rebuilding the engine and transmission?
Old 05-25-2017, 01:42 AM
  #294
No, I'm not worried at all.
Right now engine and tranny are solid. These are actually one of the most durable engines Mercedes ever made.
In the future... not sure when, but Im thinking of doing G55 engine swap.
Worst case.... a good low milage 5.0 engine could be had for around $700-$800
Old 05-25-2017, 11:38 AM
  #295
aznevoviii's Avatar
G63 AMG
or you always have option of going something non-german, such as LSx motor swap.
Old 05-25-2017, 11:51 AM
  #296
No, there are plenty of German options out there, no need to go non-German with cars like this )
Old 05-25-2017, 06:42 PM
  #297
tedcorp's Avatar
2004 G500
You nailed it. I ended up giving Gwen a little ArchOil and she loved it. Now the engine idles at a dead 600 rpm and as smoothly as the commercials said they would when the M112/113's were released. Only 249,000km on it too!
You're getting there! The Raptor lining looks like a good idea too. I've considered hitting mine at Line-X to at least stave off any further issues with the underbody.
Old 05-25-2017, 07:19 PM
  #298
I think its a good idea to use it in some places, its just like Line-X. I might use it on some areas of the underbody as well. I will probably use a small foam roller to apply it on the underbody not to get it on parts that I don't want it on.
Old 05-26-2017, 08:27 PM
  #299
Here is the final result after using Raptor. Love the way it feels and looks. Will definitely help with any future rust prevention. The blue tint on the hood is from the blue carport cover.
I will also spray some on the exterior door sills, above the running boards before I take it to the paint shop.
Old 05-27-2017, 04:57 AM
  #300
pdeacon's Avatar
Great job!!! An amazing build.
Quick Reply: 2002 G500 build/ restoration/ conversion photo thread
