Shifter bushing came loose?? Car seems stuck in neutral
mine just fell off tonight. after short drive, i went to park and when putting the gear shifter into Park, I heard a slight clunk sound from below the gear shifter and then found this shifter bushing underneath my car....
any insights would be appreciated. i found this parts diagram and can see where this bushing holds together the shift linkage to the actual shifting rod. so am hoping its easy to just snap back in assuming no other connector parts are missing. thx a bunch
http://www.mbpartsworld.com/p/Merced...039920110.html
shifter bushing
shifter bushing
trans shifting rod that needs to connect the little silver peg into to the slot in the shifter bushing sitting inside the shifter linkage <br/>
got the car on jacks and can see how the trans shifting rod came loose from the shifter linkage because the bushing was degraded... should be an easy fix. if you start hearing a metallic sound while shifting that is a sign your shifter bushing has degraded and you may run into this same situation.
the shifter bushing is #2039920010 and 3 bucks. you need the clip that holds it on also #0009945060 also 3 bucks. cheap to fix. car will start but not move when this happens
http://www.mbpartsworld.com/showAsse...roduct=7418246
I cannot for the life of me figure out how to put this clamp on the trans connect rod to hold it in place with the shifter linkage a lot.
Any ideas??? Seems you crimp it with pliers or something. It won't stay on the connector by its self it's a tad too large.
will try again..i have a tiny hose clamp on it right now which is some how holding in place temporarily until i figure this out.
its not a huge difference, but prior to the PSK i would occasionally see 18psi boost with my 178mm pulley. the PSK added and its consistently over 19 to 19.5psi with that little bit more belt wrap that the PSK provides (thats what im assuming is giving more boost as all my mods remained the same as pre-swap).
i've actually forgotten how to best launch the car and just spin the tires all the way through 3rd gear before the Pilot Sports hook up. ha.
Thanks what I had to order - its like $2 bucks but amazingly that damn thing is what holds the trans rod to the shifter
https://www.mercedesbenzstarparts.co...ock-0009945060
Crazy that a 2 buck tiny piece of metal can render your car undriveable!!!! Good luck
