Group Buy For C63 Down Pipes with and without 200 Cell Catalytic Converters
These units will be made by Mike's Customs in Russia
Pricing is as follows
Cat less version $1350
With 200 Cell Magnaflow cats $1750
Shipping will be $85 in the US
I just need 4 orders to lock in the price.
They should take about 3 to 4 weeks to make after order is place
This Mikes Custom Cat-Delete Downpipes eliminates the catalytic converters for maximum exhaust flow for the AMG c63 and c63s with M177 engine.
Key Features:
100% hand crafted in the Russia from premium French 304 Stainless Steel - flanges and O2 bungs included!
No Questions Asked 5 years Warranty!
Easy installation,no need to remove engine or gearbox
Mandrel Bent 84mm-76mm piping. Smooth transition to the exhaust system
100% TIG welded for better quality welds
Precision CNC V-Band flanges and quick release clamps
Exhaust hanger like factory that helps support the exhaust system
Compatible with the factory or aftermarket exhaust systems
Torque gains of 70wtq average (stock boost) up to over 260 wtq (software upgrade)
HP gains of 45whp average(stock boost) up to over 100whp(software upgrade)
Better throttle response and faster turbo spool up times
We do NOT grind/polish our welds as some other manufacturers do. Grinding welds compromises the strength of the weld, and can lead to weld failure!
You don't have to remove the engine or trans because the downpipes are in two pieces?
Factory downpipes will need to be cut just above the bottom cat if you don't want to remove the transmission and Mike's Custom downpipes can then be fitted.
If you want to keep your factory downpipes in tack the transmission will need to be removed.
I chose to have my transmission removed to keep my factory downpipes in tack which took approximately 6 hours.
Mailman brought presents today!! These looks amazing! The quality is excellent, I can't wait to get these babies installed!! Thanks so much for the quick responses, helpful with my questions, and incredibly fast shipping. I bought these maybe 10 days ago.
Congrates...
These are truely beautiful in design and workmanship.
I recomend having them ceramic heat coated as it will drop your under bonnet temperature significantly.
