SL/R230: oil level 2003 SL500
Old Sep 8, 2017 | 02:56 PM
wifes-sl500's Avatar
sl500
I picked uo a 2003 garaged SL500 with 45k on it. I am doing some typ car guy checking on the new addition. So I have read all the posts about oil changes and pumping as opposed to draining. I ordered the dipstick on line but in the interim, I used the dipstick from my Ram which is a lot longer just to check the condition of the oil. So I bottom it out and it comes up dry. I used a wire hanger for giggles and get a sparse amount of oil, It seemed to slide across the bottom of the pan so it should be covered on oil ...right? The sensor says the level is good. I am thinking I will need to do it the old fashion way to be sure.
Old Sep 8, 2017 | 03:57 PM
Aussiesuede's Avatar
SL500 & GL450
The oil pan on your SL500 is divided into 2 section, an upper and a lower. There is a baffle in the upper section. When your OEM dipstick arrives, you'll notice that it has an elongated thicker piece of plastic as it's tip. This guarantees that it'll work it's way into the lower pan section. Attached are pictures of the innards of your oil pan for reference...
Upper Oil Pan (Topside):
Lower Oil Pan (Topside):
Lower Oil Pan (Bottomside):
Old Sep 8, 2017 | 04:25 PM
sl500
oil level
so I did an old school oil change, just to be sure. I knew it had to be something simple....besides me
