highest miles e63 here?
Old Sep 10, 2017 | 04:22 AM
speedydriver's Avatar
E63 AMG S
what year is your car and how many miles do you have? any problems you had to get fixed (and at how many miles?) just curious
I have 21.5K miles on my 2014 but often feel guilty to drive due to the known depreciation curve should drive it more..
Old Sep 10, 2017 | 07:05 AM
iFlyer's Avatar
2012 E63 Wagon
2012. 90k so far......
90 k so far
Old Sep 10, 2017 | 11:49 AM
PeterUbers's Avatar
Old Sep 10, 2017 | 11:55 AM
PeterUbers's Avatar
2014 E63S, bought at 81 miles, now 21,000, still bone stock
airmatic issue
aux battery replaced
b pillar rattle fixed
a couple tcu reprograms
windshield replacement
alignment
re balancing after new tires
lsd oil change
three oil changes
recall work on engine bay firewall
Fabric air intakes ripped... replaced
brakes are all over 50% remaining life
couple tire leaks -- covered with tire/wheel
warranty
routine recommended maintenance all done
Old Sep 10, 2017 | 01:36 PM
E63 AMG S
Originally Posted by iFlyer
90 k so far
Any problems along the way to 90K?
Old Sep 10, 2017 | 01:37 PM
E63 AMG S
airmatic issue
alignment
lsd oil change
three oil changes
warranty
seems the biggest item on your list was the airmatic? What happened?
Old Sep 10, 2017 | 01:42 PM
E63 AMG S
And for all of you guys wondering, i've had excessive oil consumption (topped off 10 liters in 3,000 miles). That has been fixed by a warranty piston change and some engine out work. Other than that, there was a timing belt (? Not a mechanic or knowledgeable about the name) rattle that was heard through exhaust that was taken care of. Engine was taken out twice. Oh, and something was wrong with the crankcase ventilation system, which caused leakage. Overall spent probably 2 months total in the shop
Old Sep 10, 2017 | 04:03 PM
iFlyer's Avatar
2012 E63 Wagon
90k
I only put 4000 miles on it since I bought it from another forum member this Spring, so still a E63 newbie, but I'm hoping it will be a solid car. Only issues were rear airbags leaking when cold, and now I get a brief Check Engine Coolant Level on startup that goes away quickly, but coolant level seems normal. Any ideas??
Old Sep 10, 2017 | 11:47 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
90k miles here. No issues, except a minimal oil leak that I could smell but it never dripped. Turned out to be a block plug and simple fix. Other than that it's been solid and my only expenses have been on routine maintenance.
Old Sep 11, 2017 | 02:51 AM
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
32k miles on the wagon,
AC condenser leaked, gear oil cooler hoses leaked, fogged up LED headlights inside
everything was repaired or replaced under warranty.
Very little oil consumption so far.
Other than that, a rock solid car.
We love taking it on long drives.
For my taste a bit wobbly suspension in C mode when speeds exceed 140mph on long curvy Autobahn roads. I sometimes forget that the wagon is a heavy pig.
AT 33k miles, instrument cluster failed. I posted a short video in a separate thread. Car's been in the shop for 4 weeks now. Apparently, they can't get a replacement. Was given a brand new C-class wagon C180 to stay mobile. Words can't describe the difference.
Old Sep 11, 2017 | 05:18 AM
Celicasaur's Avatar
W212 - E63 AMG
2010 M156 E63 - 90k
Transmission valvebody solenoids
Cams
Lifters
Valvecover gaskets
Lambda's
Note: none of the things above really 'failed', it was more a case of preventative maintenance/modifications. The valvebody solenoids was probably the only thing that was actually starting to fail, along with the valve cover rubber seal. Lambda's were more for performance benefits and the cams n lifters were to upgrade to Kleemann items.
Been through a couple of sets of tyres all round, oem brake pads, discs skimmed...but yeah. I love this car.
Old Sep 11, 2017 | 11:22 AM
PeterUbers's Avatar
got airmatic malfunction warning and car was tracking to the left ... right rear airbag was malfunctioning and it was replaced
Old Sep 11, 2017 | 11:46 AM
dinman's Avatar
Most of them
142,000 on my 2010 e63
before i got it, it had the following replaced
pads/rotors
COMAND knob
intake manifold gasket
"loose pano roof bolt"
since i have had it (100k)
voltage regulator
battery
serpentine belt
engine mounts
sway bar end links
and regular maintenance.
BUT.
the car is not able to be driven at the moment. It wont go into gear. Thinking its the valve body/conductor plate, but i really am just taking guesses because i have no access to a STAR tool
Old Nov 1, 2017 | 11:32 AM
evilsaint's Avatar
'02 C32, '10 135i M-Sport, '10 E63, '17 GLE63S
pads/rotors
COMAND knob
voltage regulator
battery
serpentine belt
engine mounts
sway bar end links
BUT.
Had my COMAND knob fail too. Happen to remember how difficult/expensive the fix was?
Old Nov 1, 2017 | 11:59 AM
dinman's Avatar
Most of them
honestly no clue, it was repaired before I owned the car. I don't think it's very hard to replace though.
Old Nov 1, 2017 | 09:31 PM
Iron Sheik's Avatar
E 320
2016 and almost 30K miles (48,000 km)
Had the transmission solenoids 2&3 replaced as per dealer! Was downshifting very hard from 4 to and from 3 to 2 when slowing down!
Gone since dealer took care of the issue!
Iron Sheik
Old Nov 2, 2017 | 03:46 AM
godrealm06's Avatar
2014 E63 AMG S 4MATIC
2014 bought over a year ago at 23,000 miles. 35,000 miles so far and only issue was a leak from top of windshield which was fixed by the dealership. Car has been running tune with catless downpipes and exhaust going on 11 months with no issues and using the same spark plugs.
Old Nov 2, 2017 | 12:09 PM
E63 AMG S
Iron Sheik
You really drive your car very nice. glad you're enjoying your car and that the problem is solved. I really need to take my car out more often.
Old Nov 2, 2017 | 12:12 PM
E63 AMG S
Nice. did you install the tune / downpipes? or was it modded from the previous owner? also, I notice you're from Hawaii. Where from? I used to live in Oahu before I went off to college here in WA. (Freshly graduated for a year or so now).
Old Nov 2, 2017 | 01:27 PM
Celicasaur's Avatar
W212 - E63 AMG
Hey Dinman, is your car fixed yet?
Old Nov 2, 2017 | 01:46 PM
24Hours's Avatar
2019 E63S wagon; 2016 Landrover Landmark
I take the train to work every day and basically just used my '14 just on weekends or road trips. In my 3.5yr of ownership I only mustered 9,500mi onto the ODO, though with zero mechanical issues.
I know the new owner will wrack-up the miles.
Old Nov 2, 2017 | 07:33 PM
Iron Sheik's Avatar
E 320
I got the car with just over 24K on it and within 5 months, I've put almost 6K (miles)! So I do like to drive the car!
Grocery, gym, movies, errands, work! Any excuse to drive it
I've always wanted one of these and now that I finally have one, not gonna let it sit in the garage! Drive it every day
Iron Sheik
Old Nov 3, 2017 | 10:47 AM
Dalema's Avatar
GL550
Is there a good thread that tracks known / recurring issues on 13 - 14? Sounds like some of you guys have been around since inception so would probably know.
Old Nov 3, 2017 | 03:36 PM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
2014 model, bought it a year ago cpo at 12,000mi, now at 20,000mi. It needed 0.5qt oil top off after 6,000mi. Otherwise no problems. Dunno how aggressive of a driver I am, but with mixed street/highway driving I can’t get above 17mpg.
Old Nov 3, 2017 | 08:16 PM
Tylbran's Avatar
2018 GLC 43 & 2014 SLK 350, gone 2016 E63 Wagon
I have a 2016 wagon currently with 30K miles (49K Km) and I drive it every day. The only issues I have had are: the air conditioning not cooling and the eco start/stop caused the engine to stall. The dealer replaced the AC condenser and for the eco start/stop issue they replaced the transmission auxiliary relay and the transmission auxiliary oil pump - all under warranty. Everything works great now.
