highest miles e63 here?
I have 21.5K miles on my 2014 but often feel guilty to drive due to the known depreciation curve
should drive it more..
airmatic issue
aux battery replaced
b pillar rattle fixed
a couple tcu reprograms
windshield replacement
alignment
re balancing after new tires
lsd oil change
three oil changes
recall work on engine bay firewall
Fabric air intakes ripped... replaced
brakes are all over 50% remaining life
couple tire leaks -- covered with tire/wheel
warranty
routine recommended maintenance all done
airmatic issue
alignment
lsd oil change
three oil changes
warranty
AC condenser leaked, gear oil cooler hoses leaked, fogged up LED headlights inside
everything was repaired or replaced under warranty.
Very little oil consumption so far.
Other than that, a rock solid car.
We love taking it on long drives.
For my taste a bit wobbly suspension in C mode when speeds exceed 140mph on long curvy Autobahn roads. I sometimes forget that the wagon is a heavy pig.
AT 33k miles, instrument cluster failed. I posted a short video in a separate thread. Car's been in the shop for 4 weeks now. Apparently, they can't get a replacement. Was given a brand new C-class wagon C180 to stay mobile. Words can't describe the difference.
Transmission valvebody solenoids
Cams
Lifters
Valvecover gaskets
Lambda's
Note: none of the things above really 'failed', it was more a case of preventative maintenance/modifications. The valvebody solenoids was probably the only thing that was actually starting to fail, along with the valve cover rubber seal. Lambda's were more for performance benefits and the cams n lifters were to upgrade to Kleemann items.
Been through a couple of sets of tyres all round, oem brake pads, discs skimmed...but yeah. I love this car.
before i got it, it had the following replaced
pads/rotors
COMAND knob
intake manifold gasket
"loose pano roof bolt"
since i have had it (100k)
voltage regulator
battery
serpentine belt
engine mounts
sway bar end links
and regular maintenance.
BUT.
the car is not able to be driven at the moment. It wont go into gear. Thinking its the valve body/conductor plate, but i really am just taking guesses because i have no access to a STAR tool
pads/rotors
COMAND knob
voltage regulator
battery
serpentine belt
engine mounts
sway bar end links
BUT.
Had the transmission solenoids 2&3 replaced as per dealer! Was downshifting very hard from 4 to and from 3 to 2 when slowing down!
Gone since dealer took care of the issue!
Iron Sheik
very nice. glad you're enjoying your car and that the problem is solved. I really need to take my car out more often.
I know the new owner will wrack-up the miles.
Grocery, gym, movies, errands, work! Any excuse to drive it
I've always wanted one of these and now that I finally have one, not gonna let it sit in the garage! Drive it every day
Iron Sheik
