S430 in limp mode possible sensor problem
Old 09-29-2012, 02:44 PM
W220newbie's Avatar
S500
So i took the car to an indy shop and the codes p0720 and p0500, the mechanic said i need to change the output shaft sensor. Ive been to 4 parts stores and no one can help me. Does anyone have any suggestions ? I would greatly appreciate it thanks
Old 09-30-2012, 03:22 PM
W220newbie's Avatar
S500
any help will be greatly appreciated, or does anyone know a place in brooklyn with star besides the dealer
Old 10-02-2012, 06:54 AM
DRTYLNDY's Avatar
Do you mean crank position sensor? That is a very common problem with these cars. My 2000 S500 a few years ago had this problem. Good luck
Johan
Old 10-05-2012, 02:38 PM
W220newbie's Avatar
S500
Figured out what my problem was, i had to get my cluster version coded
Old 09-02-2013, 05:10 AM
JUNEBLOOD's Avatar
00 cl500 turbo 03 e500turbo w203_63 w203 m271sc/turbo
So when these codes popped up did ya steering get hard and the abs lit up and did u get a esp visit workshop
Old 09-02-2013, 09:14 AM
W220newbie's Avatar
S500
Yes, I PM'd you
The following 2 users liked this post by W220newbie:
Lemicher Huff (04-21-2020), Siberian (08-01-2024)
Old 08-01-2024, 09:18 AM
Siberian's Avatar
4.30l
Changed battery and pre safe light came on diagnostic machine won’t turn it off
Yes, I PM'd you
this seems to be my issue couldn’t see what you did
would you be able to tell me what you did to cure it
regards
kevin
Old 08-01-2024, 10:05 AM
wallyp's Avatar
2003 S500 2007 GL450
It's not really clear what your issue is - the one described early in the thread, or just pre-safe, or...
If it is the earlier problem from the thread:
Start the engine. Turn the steering full left, then full right, then back to center. Turn the engine off, wait for a minute, start the engine.
Did the warnings go away?
There are a lot of things on the W220 that need resetting occasionally, especially if your battery is marginal.
If you still have warnings, start your own thread.
Use a descriptive title (NOT something like "Need Help"!)
Give a full description of your car: (Model S430,S500, S600); Year; Market the car was built for; 4Matic or not; Anything special.
Give a FULL description of what the car is and is not doing. The more information you give, the better your chances are of getting a good guess from the Forum.
Old 08-01-2024, 12:31 PM
Siberian's Avatar
4.30l
430l srs abs bas lights came on after jump start and new battery fitted
Ran perfectly before left for few weeks with battery connected went flat new battery fitted these lights came in
went to local mechanic plugged it in to solus would not clear is a visit to merc dealer inevitable
Old 08-01-2024, 06:50 PM
wallyp's Avatar
Did you consider trying the very quick, very easy, totally free process outlined above?
Old 08-02-2024, 09:31 PM
tusabes's Avatar
Mercedes
If the problem happened after a dead battery you simply need to reset the systems .
Quick Reply: S430 in limp mode possible sensor problem
