Back up camera wiring help w203
2007 Mercedes E550
Hi All;
I own a 2005 c230 Sport Sedan, and trying to wire a wifi back up camera. Need to locate the back up lights wire and another wire for a power source for the wifi transmitter. I do have the Haynes manual for wiring diagram but it's so confusing and doesn't seem to match my wired. I think the reverse lights wire is the yellow-gray wire. What do you all think? Does anyone know what the colors of wires indicate??
Yellow gray are reverse lights? For wifi transmitter, which wire would give constant power?
This is so confusing and doesn't match wire colors?
2007 Mercedes E550
Hi All;
Did you ever receive an answer or figure this out? I am preparing to wire my camera and I need the same information.
I'm thinking grey/yellow looks like the one to use.
I tried fitting a camera to my past Rover 75. The problem connection was not so much the reversing light wire but the reversing wire behind the dash. I never did find it.
Check out post #6 in this thread: https://mbworld.org/forums/c-class-w...0-revival.html
I used the gray/yellow wire and I posted a picture of the ground.point.
constante no hay .. solo el negativo es continuo ..lo tendrias que sacar de la fuciblera trasera del lado izquierdo .... ahora si necesitas que la camara prenda cuando pones marcha atras ahi si conectas al faro gris / amarillo
Sorry to resurrect this post but i have a similar problem. I'm installing a backup camera to my '07 w211, but im confused about reverse lights' positive and negative. Any idea which color to connect?
On my car, there was a grey/yellow wire that I used for power. There was a ground point on the inside of the fender that I used for ground.
baris41 (03-15-2021)
2003 C230K Coupe Orion Blue
Just open up your light and see which one powers up the reverse bulb. One look at the circuit board and you'll have your answer.
You might also want to ask in the W211 forum.
The circuits can handle quite a bit of juice, especially if your car uses P21W bulbs. No power issues. Also no need to find a chassis ground. The ground in the harness will be sufficient.
