Sport button problem
w204 (c300) 2010
Hi I have c 300 2010 there is problem with the sport suspension mode The sport button is switched on all the time and I can't switched it off Is there any way to solve this problem?
Have you tried the at home fix as opposed to spending money to determine the problem--if no---try disconnecting\reconnect the battery what happens--if nothing--try the professional approach--see an indy with factory diagnostics or live with the issue or spend the next couple of months searching the various foreign language forums for foreign language misinformation!!
Hello,
I have the same problem. S mode is activate autmaticly everytime when the car is outside and temperature is not high than 8-9 C.
Do you know why is that ? And how i can turn it off ? I would like to drive in C - mode. All the summer was every day on C mode.
For the record it is (depending on the package), generally located on the dash instead of the C/S/M button near the gear lever. I know...I factory ordered mine and I too have the "Sport Suspension Mode".
EDIT: DOH! Zombie thread. Sorry.
huku: Mine was stuck one time too (I vaguely remember it was an extremely hot day), however it reseted itself after I shut the car off/on.
