Relay for secondary air pump
Old 09-19-2016, 10:36 AM
Fenili Luca's Avatar
C300
Hi guys i replace the secondary air injector pump and its not working. I can't figure out which the fuse and relay are i found the fuse diagram can someone please help
Old 09-20-2016, 08:33 AM
Plutoe's Avatar
1999 E300TD
post your VIN!!
Old 09-20-2016, 12:15 PM
C300
CA621248 thats the VIN
CA621248
Old 09-20-2016, 01:20 PM
Plutoe's Avatar
1999 E300TD
I am not a dealer--------I need all seventeen digits to help!!
Old 09-21-2016, 12:00 PM
C300
Vin
WDDGF8BB7CA621248
Old 09-21-2016, 03:01 PM
Plutoe's Avatar
1999 E300TD
The secondary air injection fuse(F32) and relay(N10/1kP) are located on the third bottom row of the front SAM which is on the left engine side!!
Also check the relay next to P. It is designated Q and is the backup relay for P
Old 09-21-2016, 03:43 PM
C300
Awesome thank u so much. I really appreciate it.
Old 09-23-2016, 02:14 PM
C300
Omg. I replaced thesecondary pump. Now i checked the fuse and its good plus i replaced the relay just in case and the engine light its still on. o
Old 03-01-2018, 09:06 PM
C230Ak's Avatar
2012 C63 (P31)/2006 CLK350 Coupe
I too have a general air injection code. Fuse 32 looks good, the relays are not labeled so I don’t know which one to check. Did you ever figure this out Luca? If you replaced the fuse-relay-and pump and no go then you must have a sticking valve. See if you can clean them out before replacing. Sometimes they just get gummed up.
Old 03-01-2018, 09:26 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
did you check the left and right valves when you pulled the pump? I'm going to change my whole system because I'm on pump #2. if theres carbon build up in the 2 valves then that could cause an issue.
don't throw your old pump either you can open it up and clean out the carbon build up and it not make any noise.
Old 03-01-2018, 09:35 PM
C230Ak's Avatar
I haven’t gotten that far yet. I wanted to rule out fuse/relay before going after the equipment. If both are good then I think I would test pump operation then clean out valves in that order. Or just eliminate the system and have Weistech flash my ECU to put out the CEL! I will say I don’t hear it come on after cold starts so I’m thinking faulty relay or pump.
Old 03-01-2018, 09:44 PM
MB Marko's Avatar
well march break I'm off for a week if I get to do mine before you do yours post some pic's of how yours is looking. I have literally everything to change the whole system except new hoses. what I don't need i can return but what for sure what I'm changing is the secondary air pump, fuse, relay and air injection change over valve. if i don't have to ill leave the left and right vales alone, but it all depends on how they look once the pump is off. I'm pulling the hoses so i don't need to remove the valves and buy new gaskets and waste time if the valves don't move easily and your finger is black when you tick it inside you need to change them.
i mean I've already changed the fuse and relays once my self. the pump fuse and relay were all changed 2 years ago under warranty and it went on me again making that loud jet engine noise.
i recently found that my 40 fuse wasn't clicking in the from SAM and i think my pump is already toast, now i only get the jet whine sometimes since i fixed the fuse, its random. its defiant not cheap if i have to do this every 2 years.
Old 03-01-2018, 10:04 PM
C230Ak's Avatar
I thought that jet engine sound was the normal sound of the pump. My CLK350 air pump makes that sound (like a really loud vacuum) and all seems well. Sounds like now you have an intermittent relay if it only clicks and comes on sometimes. So which relay is it exactly? It’s next to the #32 fuse I know, but that fuse is surrounded by relays...
Old 03-01-2018, 10:09 PM
MB Marko's Avatar
the one to the left of the fuse in the yellow box, I'll add i just found this image on the net its not my SAM unit lol
Old 03-01-2018, 10:19 PM
MB Marko's Avatar
this is what my pump sounded like when the dealer fixed it under warrant but sometime i get a very loud whine, this guy shows how much carbon is built up in the pump it should be virtually quiet.
its 100% carbon build up in the pump because its just bearings in the bottom of the pump. he blows it out with an air hose and you should see the **** that comes out of it and how quiet it is . it sounds normal like vacuums with the hoses off when he tested it.
great video!
Old 03-01-2018, 10:27 PM
C230Ak's Avatar
https://www.youtube.com/watch?v=zO8BvhF09aU
great video!
Well you’re better at the internet than me! Haha. I find lots of sams but never of a w204 with anything identified... Very helpful! Thanks! I’ll snap some pics of mine with that relay identified on other forum posts too, lot of threads out there without an answer.
Maybe I should take a look at the pump in the CLK too then. If I can save it before it seizes then that’d be great.
Old 03-01-2018, 10:33 PM
MB Marko's Avatar
hahahah i've forced myself to learn the whole system because it would cost $2000 at the dealer to fix this issue when it can possibly cost you $0-$30 with just a new relay and fuse, just by taking it apart and using an air gun lol.
if your in the states you can buy a new pump for $180US, I'm in canada it cost me $280CAD. i bought but I'm hoping to get to the pump before it seizes, i want to clean it and save it for if it happens again. I went with the Bosch pump it was much cheaper than the Mercedes OEM one and it probably is made by Bosch anyways lol. its not a hard job at all and could save you money. I need to find a place that sells RELAYS for less then the benz dealers $25CAD price.
I know ill do mine march 10th-15th when I'm on holiday. I'll post some pictures on here.
let me know how it goes!
Old 03-03-2018, 05:51 PM
C230Ak's Avatar
Pulled the pump apart on the CLK and it didn’t look terrible inside. The motor turns smooth and there was a little graphite dust but not alarming. I took a closer look at the SAM on the C and the fuse #32 actually is blown. Tested the relay for grins and it clicked happily as a fly on dog **** in July. I’m going to put in another 40A fuse and if it blows again then I’ll dig out the motor (if the windings are shorted then I’m sure it’ll have to go) and take a look at it. I don’t feel like getting on the ground and pulling the trays off to get at it right now with all the snow melting...
Old 03-03-2018, 06:35 PM
MB Marko's Avatar
well thats good I hope its all fixed! I can't wait to do mine next week but until then i have to listen to the jet engine for like 40 seconds! i mean its embarrassing everyone looks and sees a mint benz making a really bad sound lol.
Old 03-10-2018, 01:44 PM
ChatWithaNinja's Avatar
2010 R350, 2012 CLS63 P30 (sold), 2009 C63 (totaled), 2002 ML320 (Sold)
Nice picture. I've been trying to find this relay for a while.
I see that port "Q" is empty, but a previous poster said it was the backup for the "P" relay. What kind of relay should be in the "Q" port? because the "P" relay does NOT fit in there. The green relay has the right "poles" (yeah, I use a lot of quotes because I don't know the proper term, sorry) that will fit in the "Q" port...
Also, My mechanic told me that the air valves can weaken over time. They can pass the initial test, but then they can fail during the 20 seconds or so that the air pump stays on causing the O2 to read that the pump isn't doing its job. just thought I'd throw that out there...
Old 03-11-2018, 09:33 AM
C230Ak's Avatar
Yeah, not sure what that poster meant about a backup relay. My slot is empty. One thing to keep in mind about Benz is there is not as much standardization as you’d think. They may have at one point put extra relays in there and stopped at some point.
And it’s so true that as they get older, these systems can fail in unique and creative ways, lol. You have to go through and verify each component. My car is a 2012 with only 45,000 miles though so l lucked out and it was just the fuse. It still bugs me that the fuse blew in the first place though. Is a new pump in my future? Maybe.
And one more shout out to MBMarko for that very helpful pic! Someone should sticky this since it’s maybe the only thread on the topic with the answer posted clear as day in a photo nonetheless!
Old 03-11-2018, 09:50 AM
MB Marko's Avatar
No worries! I really don't want to change the left and right valves.... I hope I don't find carbon build up in them. My pump sound even worse than a week ago. I pretty much went with the None OEM route. the parts I got are the ones pelicanparts sell through a local dealer,. There all made in Germany Hella relay,Bosch pump and Peterborough switch, I will be doing the work tomorrow and can't wait to see what I find. If I need to change the left and right valves there're the only things I bought from the dealer.
I'll post some pictures if I get to opening the old pump tomorrow.
Old 03-11-2018, 10:05 AM
superangrypenguin's Avatar
A car
Out of curiosity, what happens if you just disconnect the SAI?
I know it's just for emissions reasons that this damn thing exists..
Old 03-11-2018, 10:08 AM
MB Marko's Avatar
Last time my pump failed the check engine light went on and the car showed 2 codes. I cleared the codes with my scanner and they came back after starting the car.
I should add I've read that gas milage is worse and the car can run rich. This system is ridiculous. If I could take it completely out I would lol!
If this pump fails on me again I might post a video of me blowing up my the secondary air pump with dynamite.
Old 03-11-2018, 10:16 AM
A car
LOL - that'd be quite a Youtube video!
Totally get that a car would show codes - it's designed that way. That said, the SAP (love that acronym) should turn off after reaching a certain temperature and/or 90 seconds has elapsed. I don't know why your gas mileage would be worse or the car would run rich because the pump is turned off.
If one can live with codes, I'm fairly certain there is no harm to the vehicle if the SAP is disabled.
Quick Reply: Relay for secondary air pump
