Does your speedometer cheat?
Old 02-17-2017, 07:23 AM
blizzard12's Avatar
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
I get the impression that my speedometer (2017 C300) shows a bit (5%-10%) more than the actual speed of the car.
I haven't got a chance to measure it yet, but based on my driving habits something seems to be off.
Did anyone else notice this?
Old 02-17-2017, 09:55 AM
Cbc200's Avatar
2020 GLE 350d AMG Line Prem+
Yeah I have noticed this as well, near me there are road signs that show your speed as you drive past then, I've tried going past at various speeds and at 33 on my digital speedo the sign shows 30-31.
Old 02-17-2017, 10:10 AM
clifish's Avatar
2016 c300, 14 Explorer, 74 TR6, 81 Corvette
maybe that's the reason when I picked up my car and looked down I was going 110 MPH?
seemed more like 60
DapperStyle (02-17-2017)
Old 02-17-2017, 10:12 AM
blizzard12's Avatar
seemed more like 60
Old 02-17-2017, 11:35 AM
KDaFrank's Avatar
2017 C300 with Luxury Package
I think this is pretty standard -- something about it being illegal for the speedometer to under report the current speed.
My prior car (99 3 series) did this too.
Old 02-17-2017, 11:47 AM
blizzard12's Avatar
Volvo doesn't do it. Volkswagen on the other hand does. Big time! 10%!
Old 02-17-2017, 02:57 PM
AAN
AAN's Avatar
2015 C300 Lux 4MATIC
I have driven many rental cars in France where there are many road speed measuring signs. All cars show slightly higher speed than the measured one. Different brands, different years, so I assume this is normal.
Old 02-17-2017, 04:27 PM
GerritKw's Avatar
C350e
In the Netherlands all cars standard indicate 1-3℅ more. This is a safety margin. Different wheels might have different diameters and that can change the deviation in a positive or negative way.
Old 02-17-2017, 06:25 PM
WhiteMerce's Avatar
2017 C300
I experienced the same in BMW 3-series and Infiniti G37. Manufacturers do not want to be responsible for your speeding tickets.
Old 02-18-2017, 02:34 AM
AmrDXB's Avatar
C 250 (W205)
That's normal.
Old 02-18-2017, 10:10 AM
Mike5215's Avatar
2016 C300
YES! I came home from work early one afternoon and caught my speedometer with my tachometer!! I always saw them together but I thought they were "just friends". I don't blame my tach though; that speedometer has always been a *****.
Old 02-18-2017, 05:19 PM
PR2000's Avatar
2017 C43 AMG Sedan
I would say about 3-4% on mine based on road signs measuring speed in Canada
Old 02-18-2017, 08:18 PM
Bueller178's Avatar
Polar White C43 Sedan
Why does everybody assume the road measuring signs are accurate?
Old 02-18-2017, 09:37 PM
pjw1967's Avatar
2014 ML350 2w, 2017 GLS550, 1967 Pontiac GTO 4 sp
There are a few speedo apps for iPhone. I used one to check my GTO speedo after the trans was rebuilt. Tranny has 2 gears to turn the cable. Gears are diff colors. I had to get the right match. Never did though. Speedo overreads by about 5 mph vs the speedo app.
Old 02-19-2017, 07:42 AM
BenzC400's Avatar
2019 E53 Coupe
A properly calibrated and accurate speed measuring device (RADAR or Laser), will only give an accurate speed when a car is coming directly toward it. As the angle between the RADAR or Laser unit and the car being measured increases, error is introduced. The error will always favor the driver (the RADAR unit will show a slower speed than the actual speed of the car). So, if the RADAR unit for a speed measuring sign is at the side of the road, you can expect to see a lower speed on the sign than the speed on your speedometer.
Speed signs that just show your speed and are not used for enforcement may or may not be routinely calibrated and accurate.
Old 02-19-2017, 05:36 PM
Lionel_Hutz's Avatar
C43
Very typical for German cars
Old 02-22-2017, 07:15 PM
Waveform2's Avatar
C250 with AMG bits n peices
Most speedos do to keep you out of jail.
Old 02-23-2017, 03:32 AM
Luton Driver's Avatar
C Class 200 sport petrol auto
I would have thought that the accuracy of the speedo is dependent on the size of the tire fitted. The bigger the tire the faster you go for the same revolution.
Old 02-23-2017, 10:53 PM
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
Question Try GPS
Who says the road side speed measurement signs are more accurate than your speedometers? Your GPS (esp. a freestanding one) should be the most accurate measurement. Has anyone compared their speedometer with a GPS? (I have not done so yet.)
Old 02-24-2017, 04:43 AM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
I have a freestanding GPS that gives MPH readout and have checked it against both of my cars. My ML was dead on. My C300 speedo actually measured between one and two MPH low, so I was going faster than my speedo indicated. Measured at 70 MPH on the interstate. Seems to go against what most people are saying.
gfmohn (02-24-2017)
Old 02-26-2017, 09:12 PM
Mr. J's Avatar
C450, GLC43
It's the car.
I passed a slowpoke on a country hwy today, glanced at the HUD and realized I was doing 87mph in 3rd gear The car felt like it was on greased rails.
Old 02-26-2017, 09:43 PM
gfmohn's Avatar
Cool Beep! Beep!
Originally Posted by Mr. J
It's the car.
You must have been dreaming that you were back in your old Nash Rambler:
Beep! Beep! (Beep! Beep!).
His horn went Beep! Beep! Beep! Beep! Beep!
Now we're doing a hundred and twenty, as fast as I could go,
the Rambler pulled along side of me as if I were going slow.
The fellow rolled down his window and yelled for me to hear,
"Hey, buddy, how can I get this car out of second gear?"
(Donald Claps & Carl Ciccheti, The Playmates, 1958)
Old 03-05-2017, 04:32 PM
pjw1967's Avatar
Went on I-45 S to Houston this morning. Wifey driving her '14 ML350. I opened up Waze to get traffic info. Lower left on Waze shows your speed vs posted speed. I glanced over at the speedometer and it was right on. 65 on speedo, 65 on Waze. At no time did the speedometer vary from Waze by more than 1 mph.
Old 03-12-2017, 04:37 AM
grege's Avatar
17 E220d all-terrrain, 92 SL500, 16 C250D Wagon, 16 A200 (wife)
As part of making an electronic throttle (for disabled people) we found that the Canbus reports the right speed but the dial speed reads 4kph low right from the bottom. (01 W203)
I think pretty much all do this, not really any reason in a digital world to have speedos that are not right on the correct value, tire wear even has a pretty tiny impact.
I'm sure its a deliberate policy. I always add the extra 4kph to my speed plus whatever margin over I feel like doing!
Old 03-12-2017, 06:04 AM
Mjollnir1983's Avatar
W205 C250 Sedan
I read some where MB says odometer is calibrated 2km under the speedo shown.
Using my GPS dashcam, it is pretty much spot on.
