Cracked Rim due to Runflats - Stock 18s
Ran over a supposed large pothole 3 weeks ago and just developed a slow leak about a week ago (-8psi/day). When I had the tire checked, I noticed two cracks about 10inches away from each other on the circumference of the inner lip. Got it done from a reputable local wheel shop here in Philly for $275 to weld, repaint, and rebalance the bent wheel. So far, I'm happy with the results but in the end of the day, I know that pothole was not large enough to have caused this damage but instead, it believe it was the firmness of the runflat and its inability to absorb hits that caused the cracked wheel.
Just wanted to share. Be safe out there guys! Its pothole patching season!
Btw, i drove by the pothole on i95 south bound ramp entrance from GWB to i95S and saw that they had a road crew patching the hole.
Added some pics, I hope everything in my suspension looks alright. The car drives fine and it drove fine even before the wheel was fixed.
I'm not sure about that. A buddy of mine runs a tire service center here in town. From his perspective the run flats, especially on fitments where the sidewalls are short, are prone to either sidewall ruptures or bent rims. That energy from the pothole impact has to go somewhere. If the sidewalls are stiff (and run flats by design have sidewalls tough enough to support the weight of the car on their own) the energy is going to expose the weakest component at the moment of impact.
Run flats can serve a useful purpose. If you stack them up in a corner of the garage you can store a lot of rakes and stuff in the middle.
