E-Class (W211) 2003-2009
Front Spring Broken
Old 05-21-2017, 11:02 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Front Spring Broken
Backing out the garage I notice the car was "unsprung" so stopped and sure enough the LF spring is broken.
I don't know when it happened because SHMBO pulled the car into the garage and is the regular driver.
We had a rear spring brake last year. I was told it is not uncommon in Chicago due to salt use on the roads.
The spring is down around the bottom of the shock. From my quick look, I could not see where it should have been siting. (Is it common to work its way past the retainer, or do retainers also fail?)
How hard it sit to change? Are there parts usually needed beside the spring?
(Rubber spring pads, etc.)
Old 05-22-2017, 02:21 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Not super difficult but you'll need a spring compressor.
Old 05-22-2017, 08:53 AM
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
Ditto
Quick Reply: Front Spring Broken
