Battery Drain! Need HELP pls!!!!
Old 11-06-2017, 05:28 AM
Octaw's Avatar
Mercedes Benz CLK 200 W209
Exclamation Battery Drain! Need HELP pls!!!!
Hello everyone,
I really need your help because I have a problem with my car already for 6 months. The car run out the battery in 2 days if I don't use it.
I went to the dealer and they told me that the Rear Sam could be the problem. I changed it but in vain.
I removed all the fuses, I disconnected the driver's and passager's seats control module ( a common problem that drain the battery) and I have measured the battery but I didn't find the problem.
Sometimes but very seldom the consumption is 0.08 A which is the normal one but if I repeat the measurement after several lock/open doors, the consumption doesn't decrease anymore.
I found a cable that goes from the prefuse box (near the battery) to the interior fuse module and has a high consumption.
I don't know what to do anymore. I have already been to 3-4 services...
Somebody told me that the key lock ignition switch could be the problem... but nothing is sure.
I would really appreciate some advices from you and hope that I'll fix that problem.
Thank you!
jwb007 (09-07-2019)
Old 11-27-2017, 05:28 PM
skinnywillie's Avatar
E350
draining of battery E350 2007
I have the same problem and no one seem to have a solution for this draining of the battery. First I changed the battery, then came the alternator, then the control module, and with all of those changes battery dead after 2 weeks from the dealer. took it back and now I have been advised thatTthe problem is interior light. New interior light is on order but will take 4 day shipping.
the only thing for sure is that no one know what is causing this problem,.There is only one solution, buy a NOCO Genius G15000 Ultra Safe Smart Battery Charger connect it and keep it in the trunk at all time until someone come up with a solved problem.
The following 2 users liked this post by skinnywillie:
jwb007 (09-07-2019), Octaw (11-28-2017)
Old 11-28-2017, 03:03 AM
Octaw's Avatar
Thank you for your advice. My car is still in service, but for now nobody identified my problem. I also change the battery and now I changed some parts from alternator like alternator relay. However it seems to be a module that doesn't go to sleep, but it is very hard to identify which one is it. In order to use the car I remove the battery terminal but definitely a smart battery charger is also a good solution.
How did you realise that the problem could be the interior light?
jwb007 (09-07-2019)
Old 11-28-2017, 08:11 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I was talking to a tech the other day about selling my c32 because I was fed up with the battery drain issues. He mentioned that the CD changer in the trunk will fail on and drain the battery.
jwb007 (09-07-2019)
Old 11-28-2017, 08:29 AM
mosysav's Avatar
2001 Mercedes w203
Could be the driver or/and passenger seat module.
They are under the seats. You can disconnect them and see if there are some changes.
jwb007 (09-07-2019)
Old 11-28-2017, 08:45 AM
Octaw's Avatar
Hello guys,
Thank for all the advice you gave to me.
@mosysav. I have already disconnect the driver and the passenger seat module and I didn;t notice any changes
@insame1: I have a CD changer in the glove box. I don't know how to identify the problem because I removed all the fuses and nothing change. The consumption is about 0,98 A /h.
jwb007 (09-07-2019)
Old 11-28-2017, 09:50 AM
E350
In reference to draining of the battery on my E350 2007 with only 96,300 miles. I took it to the Mercedes Dealer after being told the alternator was the cause, the Mercedes ran the test and found the Gateway Module was draining at 2.5 amps, changed it by installing a new Gateway which it to 0.02. This lasted for 3 weeks in which the battery drained again, towed back to the dealer and this is when they told me about the interior light is draining the battery. The part is now on order but after reading the same problems being posted here, I think I will not allow the shop to install the new light because I think the problem is deeper and will show up as another item to be replace. Going forward I will only use the ultra safe smart battery charger for a while or until someone can post the real solution for the battery draining problem.
jwb007 (09-07-2019)
Old 11-28-2017, 10:06 AM
JimVonBaden's Avatar
2005 CLK500
I've been having this issue for the past 6 months. No idea what it is. Time to sell this POS. I have had so many small issues with it, one causing me to be stranded twice, that I am over the good features of the car. I need a little more reliability than this from a 64K mil car.
Old 11-28-2017, 10:14 AM
E350
After this ordeal car ownership is over, I will lease for now.
car ownership
Octaw's Avatar
Ah, ok, I understood.
Indeed, it is very hard to say what cause the battery drain. When I will find the solution I will post here.
I also kindly ask you to tell me if the problem is solved after you change the interior light.
Let's hope everything will be OK.
Best regards!
jwb007 (09-07-2019)
Old 11-29-2017, 12:21 PM
Former Vendor of MBWorld
Mike Bender's Avatar
Mercedes Benz
We specialize in Leasing, financing, trade-ins, and lease terminations!
we can deliver ANY MAKE AND ANY MODEL to anywhere in the U.S.
If you are looking for the best price, just contact me.
Old 11-29-2017, 12:59 PM
insame1's Avatar
what is this junk. We get spam in the forums now. great.
jwb007 (09-07-2019)
Old 12-14-2017, 07:48 AM
Octaw's Avatar
I took the car out from service but without any results. They checked the front SAM, seat modules, interior light ...
The only error on the STAR is : S40/4 (TPM touch switch with variable speed limit). Can this error lead to battery drain?
Any other advices??
Thank you!
Old 12-20-2017, 06:10 PM
Reanimation's Avatar
270 cdi w209
Have you tried a new quality Battery? And I take it the garages have Performed a Parasitic Draw Test?
Old 12-21-2017, 02:56 AM
Octaw's Avatar
Hello,
Yes, I replaced the battery with a new one (Varta). In fact, that was the first thing I made after I noticed that the car has no power, because I thought that the old battery is the problem.
Recently, I've discovered some interesting. The steering wheel controls from the right side didn't work property sometimes (see photo).
After I've stopped the car and restart the engine everything seems to be OK but maybe there is a fault at the steering wheel that drains my battery...
Regards,
Octavian
Old 12-21-2017, 02:16 PM
Anker's Avatar
2009 CLK 350
Check to see if there's a mouse nest under the dash! Seriously!
Old 12-21-2017, 02:45 PM
Octaw's Avatar
Hi Anker,
I also thought about this but I didn't see anything.
Old 12-22-2017, 04:39 PM
270 cdi w209
[QUOTE=Octaw;7340295]Hello,
Regards,
Octavian
[/QUO
The Parasitic Draw Test needs to be done First then I would be taking the Steering wheel off to see whats wrong with it.
jwb007 (09-07-2019)
Old 03-25-2019, 11:57 PM
Ryno420's Avatar
2003 clk500
Easy fix
No need for battery charger!! My easy solution was to install a kill switch on the battery. When I get home at night I simple turn the battery off. I turn it on when I leave for work in the morning. I don’t bother turning it off when I get to work. Battery seems to have drain issue when sitting over night or for longer then an 8 hour period. I have had this for over 6 months now without any issues except the occasional time to time that I had forgotten to turn the battery kill switch off
Old 03-26-2019, 09:05 AM
insame1's Avatar
You didn't fix the issue though. I sold my c32 because of this and it burned shortly after.
jwb007 (09-07-2019)
Quick Reply: Battery Drain! Need HELP pls!!!!
