A little help please
2018 E43 | 2017 GLS450 | 2004 CLK 500
I had the exact MAF issues for 6 months. Changed the MAF 3x and then the prob went away when I tossed my 55k intake with k&n’s. Maybe just a coincidence, maybe the intake wasn’t sitting snug.....
I know theres alot of threads out there about this but i just want to bash this company real quick and say F@$% THEM, i bought there air filters, had them in my car for less than 100 miles. Noticed a little idle problems so i switched back to paper. Today i went for a drive ( with the paper filters ) i came to a stop and my car started to rattle and all of the warning lights came on, i quickly pressed on the gas and zoomed home afraid of stalling, right when i was about to turn the car of the CEL came on. Im almost positive its because of my MAF sensor, i have the spray but cant get the damn thing off, would it be okay for me to spray it without taking it off? Im really pissed off, i had them on for less than 100 miles, they even made a video "proving" that oil doesn't get into the system, they are f@#$ing lying out their asses. I really believed them and shouldnt have. I found some MAFs from bosch for 80 bucks, should i just replace it? And will my CEL go off or do i have to delete the code.
Clk 350
Clk 350
k&n, they are gsrbage, i went back to paper filters within 100 miles and out of no where my car tried to stall on me ( all of the lights came on ) i quickly pressed on the throttle and all warning lights went away, i raced home as quick as possible and as soon as i pulled into my drive way the CEL came on. Im afraid to drive it now, i dont know if its gonna break down on me
Clk 350
and what do you mean 55k intake? And did yiu take it somewhere amd they told you that you needed a new intake
Clk 350
is this the code that you got that made you have to get a new intake manifold?
You should not have to remove the MAF to clean the sensor. If you look into the MAF you will see a small seemingly glass enclosed reddish device toward the driver side. I believe that is the sensor and you can spray it through the screen. The MAF cleaner spray evaporates pretty quickly. Give it a couple shots of spray. The sensor should look clear and you should be able to see the red (I think) internal device through the clear covering. Wait a couple minutes and give it a couple more shots. I also spray the MAF sensor at each oil change.
