Horrible sound, Burmester 3D system.
Horrible sound, Burmester 3D system.(VIDEO)
I had this problem since the car was new, in April 2018. The sound Is mostly great, but when I change the song, I brace myself because of the possibility for terrible sound. I lose a lot of enjoyment from this. I love this car, it is great.
I never had this problem on other cars ever. I come from a W212, and a loaner w214 both with great sound systems.
The sound is like a broken speaker in some songs. It took some time to identify the problem. It never comes when listening to radio. Only Spotify or Tidal. It is worse via Bluetooth, than cable. It is also worse with the “sound effects” turned on. That would be the 3d system. “pure” does reduce the problem. It also helps to turn down “speed volume adjusts”. It also comes only on some songs. I had a Samsung S7 Edge and the android auto was horrible on the display, so I changed it to Iphone x. I also tested with other phones, and the problem is still there.
The dealer tested an older pre-facelift s-class also and said the problem is also there, but to a lesser degree. They were willing to change 3 of the speakers in the roof, to test what the problem was, but it was not possible to order. They did change the front right speaker, and that also wound not unscrew itself. This did nothing.
I suspect there is an error in the software or some other component in my car, not the speakers. There should be cd quality in Bluetooth if they use the latest hardware, and cable should eliminate this.
I do not know if it is only my car that is affected, and that is why I need your help. Please test, and repost back. The problem is mostly in the first 10 seconds of the song, so just change songs rapidly to hear it. Please test this in your car with or without the 3D system. Please also test if you have a W213.
Here is a playlist that has only problem songs.
https://open.spotify.com/user/rogerl...RFu9t0rbgDd5Hw
https://tidal.com/playlist/d12e541c-...8-f84f55448249
Here is also a list where the problem never comes, even on Bluetooth and all systems turned on.
https://open.spotify.com/user/rogerl...TnyzwKby17A4yA
I you test, please report back your car, production year and sound system.
Mine is W222 S560, 2018, Burmester 3D, HORRIBLE SOUND!!!
Is it the same songs or does it happen randomly? Are you using the cellular system on your phone to stream the music or via WiFi in the vehicle?
Nice Ride (08-03-2018)
Another question I would ask would be if it happens when you go through a mountainous area or around an area that is dense with tall structures. Another thought is when I was in Bergen, there are lots of tunnels. Does it happen when you are going through a tunnel?
2019 S560, 2022 Audi S8
Its definitely NOT the speakers. I don’t even think it’s the amp. Without getting the answers to the questions I asked, I can only speculate. But I’ll throw this out there anyway. It’s a problem with the streaming and/or connection. Absolutely nothing wrong with the cars audio system ( speakers-amps-crossovers or wiring ).
Buy a couple of those songs on iTunes, convert them to apple lossless in iTunes then upload and play them through your phone. You should notice a huge difference.
Warehouser (06-21-2018)
This is happening when using a phone. With the facelift i have the option of using bluetooth or cable with apple carplay or android auto. No difference in apple/android, but a big difference with Bluetooth or cable, but still horrible on most of the songs in the list. If i use cable and turn all audio enhancments off(use pure and other things), i improve this at least 70%. But then the sound is not so good. I never heard this in any car.
I agree. If it were the car's system, I think the problem would linger for longer than just the first 10 seconds of the songs. The source of the music (phone?) may be giving off too much preamp signal distorting the sound, then probably levels off after the car's radio or the phone's system levels off the preamp. Try turning down the volume on the source (phone) and use the car's amp for volume increases.
There is some problem with the stream. But i cannot identify it.
I do not think this sound will come from an SD card. Radio works just fine, and is never a problem, both DAB and FM. We have huge taxes on all things that are fun, including cars.
Same problem
Just bought a C43 and I thought the speakers were blown, specially on some songs they just sound terrible. Not so with radio.
Please let me know if someone finds a solution for this, it super annoying, I can´t listen tu my music on spotify at all.
2015 S550 4Matic
Here is a wild guess: do you have HeadsUp Display? Does the bad sound resemble "radio static"? If so, when it happens press on the edges of the plastic lens(above dash) of the HeadsUp Display.
Maybe you could post an audio recording of the sound.
Warehouser (08-04-2018)
This is most worrisome. I too use Spotify and am thinking about buying a new W222 with the 3D Burmester stereo option. This is disconcerting to me that MB may have overlooked Spotify as a source for music!!!
To OP: try ensuring the Spotify stream is set to the highest quality. My phone has an option (S9) to simulate dolby surround or all of that crap. Make sure they are turned off for your car's streaming purpose.
Yes, I realize that. I'm just wondering if the low quality sound from internet streaming audio is contributing to the problem; however, I do agree with you, it's probably a spotify/phone issue.
As stated numerous times in this thread, this is not Burmeister problem, it’s a Spotify issue. If the radio sounds fine ( and I assume all other media as well ) then there is an issue with Spotify. Try Pandora or Apple Music. Then get back to us. If the other streaming services don’t work well, then it’s an interface issue. Good luck!
I drove by a local stereo expert and they told me the processor was broken if no update could fix it. They heard the same problem, and when switching to radio there is no problem.
After a lot of back and forth with MB HQ in my country, further action is declined. This will of course not work for me for a car costing over $270k, so i am driving to MB HQ in my country soon. They are willing to look at the car, but they dont understand the problem. I think they will figure out the problem in the end.
Audio recording is a great idea, i will try to do this in the next few days.
I have head up display. No it sounds like a broke speaker. And it sounds like it is from every one. Even the one they changed.
I do NOT think it is a Spotify problem. This happens when the audio source is a Phone. I use a Iphone x. I also have several Samsung and other phones testet. Same result. I tested several music services. Tidal apple radio apps. Same result. regular radio works great, never a problem.
It is very bad. On the top stereo system this should not be. My last car was a E220 diesel from 2010, and it had a tune2air module retrofitted for $70. Worked flawless. HK system was great. I do not think Spotify is overlooked, i think there is something else wrong.
It is a phone issue, but for all phones. But it could also be just my car. I am begging anyone with the facelift to try my playlist.
I have had my car in several times, and the tech is able to replicate my error from his phone. The issue is the same, but less with cable. He has also tested with a pre-facelift car, and tells me he can hear some of this sound it that car. But he only has one to test.
I will be in a brand new W222 with the 3D Burmester Stereo this Friday afternoon (test drive). I will most certainly be trying it with my phone/Spotify!
The link is in the first post, also there is a Tidal link.
Here is a video:
It is MUCH more noticeable live, on every song on this list, but at 1:34 it is very noticeable. When playing low it is not present, or very little. With Apple Carplay it is maybe 60% reduced. Later i turn off the audio gimmics, and it gets even better, but still present.
You may notice it is mostly the same sound that gets warped. So everytime i hear this sound in a song, i brace myself, but it only comes sometimes. Not what i wanted when ordering the most expensive S560 i could buy.
This is a first world problem, and not my highest priority. But i paid for the system, so it better work better than my old E-class.
I do not know why the video is so low resolution, it was filmed in full HD(they fixed it now, was 360p), but youtube did something, and its the audo that is important here. Also sorry for the dust.
Here is a video: https://youtu.be/6uwTNUAxFeQ?t=91
