Keyless Go Push Button Start Problems
Recently (last 6 months) the Push button start in our 2014 E250 has intermittently failed to start. The starter makes a sound and effort to start, but stops. Usually happens first attempt during the day. I pop it out with my fingers and start the car with the key. After that, the push button start usually works normally. I think it might have something to do with humidity or temperature, but I can't tell. The car is garage kept at night and during the day. All normal MB maintenance has been completed as per MB schedule.
Any ideas or advice?
Thanks in advance
Thanks in advance
2016 E350 Sport
If you haven't already, I would first check the charge in the remote battery, or just install a fresh battery. Then, remove the button and blow out the ignition socket with Computer Air, and then thoroughly wipe/clean the business end of the button to be sure it isn't dirty.
My older MB worked via IR sensing of the key in the ignition. That key had an obvious round window in the key, and a corresponding window in the ignition. The newer keys don't have the round window, so if IR is used to read the key (or the button) it isn't obvious. Bottomline, cleanliness of the contacting parts may clear up the problem.
There isn't much else you can do from the outside. If that doesn't clear up the intermittent failure, then I would suspect something within the switch itself. Let's hope it isn't that.
The following 2 users liked this post by DFWdude:
pierrejoliat (10-26-2022),
stevil555 (07-10-2018)
Yeah, when did you last change the fob key battery? Most get 6 months to a year of life. I get about a year out of a fresh battery. If you store your key too close to the car they may try to communicate when you aren't around and wear down the fob battery. I have had issues in the past of my key and proximity to my iPhone causing issues, so I never keep them together any longer and the start problem or key recognition issue has not returned. These cars can also be started with a completely dead fob battery, so keep that in mind if you have a more serious issue and the fob does not open your door. Use the blade key to get in and remove the push-to-start button and insert your key to start. It will start the car with a completely drained fob battery.
The following 2 users liked this post by KEY08:
2010 E550, 273 Engine: 2012 S550, 278 Engine
Thanks in advance
Thanks in advance
As a troubleshooting step start the car with the key insted of pressing the button as the first try. You say pressing the button initiates the start process but the car does not start. Then you remove the button and it starts with the key. Could be that the first try with button primes the engine fuel delivery ststem and then it starts with key.
2016 E350 Sport
The car will start with the key in the ignition, because the key uses a different (failsafe) system to start the car, as I described above. If the car wakes up (position 1) when you push the button -- but does not start -- with the key in your pocket, it most likely is because something is amiss with the wireless recognition of the key. Pressing the button a second time will not help the system recognize a key it did not recognize on the first try.
Checking the battery is the first step, and a very simple one, too. Please let us know what develops.
2016 E350 Sport
No, just not true. The thing that causes communication between car and key is something physically touching the car, like your hand on the door handle, or pressing the start button, and the car THEN needs to see where the key is. The car doesn't just randomly search for the key, thus depleting the key battery.
In reading several threads here, I believe the key transmits a signal anytime it is moving. If it sits still on a countertop for several minutes, it turns off to conserve the battery. On the other end, the car is awake at all times and scanning for a valid key to walk into range. As you walk to the car, the key (now in motion, awake and broadcasting) is sensed by the car which is now ready to respond. One need not touch the car, as evidenced by the motion sensor activated trunk opener (no touch necessary to open the trunk, even when the car is locked). No touch necessary to unlock the doors from afar, either.
What is not clear to me... If you leave the key in the car at rest (engine off), will the battery drain until the key (also at rest) times out? Or will it stay on as long as it is actively linked to the car?. That will really drain the key battery.
Either way, it's recommended not to store the key anywhere near the car, so don't leave it in the ashtray when you park it in the garage and walk inside. Take the key inside with you (out of car range) and sit it someplace where it will eventually turn itself off.
Either you do something with the key fob or you do something at the car, but they don't just talk to each other to see where the fob is without specific input. Think about what you said. It does not make sense to build a system into a car in that manner.
I don't think this is true, either...
Sure, there is a sensor for the motion sensor for the trunk, similar to touching the car. You can't unlock the car from afar without a key fob in use, physically pressing the lock/or unlock button.
I keep my key near my car about 6 ft away ALL THE TIME. My fob battery lasts as long as yours does.
^ ok, then how can I swipe my foot under the car trunk and the trunk will open. I have not touched the car nor my key fob. Is that trunk sensor constantly powered up and active 24/7 or does the car sense the key in range by monitoring for a signal?
2016 E350 Sport
How would the car know if the key was entering proximity? And why would the car do that? Does it do that 1 time every minute? every 10 seconds? Every second? If it did, surely your battery wouldn't last even a month. What happens when the car wakes up? What does the car do?
The key sensor is one of them. The car wakes up to a higher state when its (active) sensor detects the presence of the signal from a valid key tied to the car.
If your car is parked in the garage when you are out of town for days, take your house key, but leave that bulky key fob in a drawer where it doesn't move and turns off. Then, only the car is semi-awake.
There are several posts here quoting dealer service techs cautioning that you should store your key out of car range to preserve its battery. Do a search.
KEY08 (07-11-2018),
pierrejoliat (02-21-2021)
and this is how thieves have been able to steal your car without the key. They grab the signal from the key in your home stored by your car (6' away for you, which is in your garage). that signal is transmitted to another device which is placed near the car. The car senses it, wakes up, the door opens and the bad guy drives away. There was a story on the news the other day that said to drop your keys into a tin can at home to thwart this active high tech burglary.
The car monitors the car trunk sensor, which is powered by a HUGE BATTERY in comparison to what is in your key fob. When it senses the movement, it then sends a signal to the fob to see if the fob is nearby, and if it is, message sent back to car and trunk opens. This is the same process as opening a door, except that there is no physical touch required for the trunk. For the door, the car monitors the door handles which are powered by a HUGE BATTERY in comparison to what is in your key fob. You touch the handle, car senses the touch, it then sends a signal to the fob to see if the fob is nearby, and if it is, message sent back to car and door opens opens.
2016 E350 Sport
Sonnyslope48, page 91 of the owner's manual describes how to deactivate Keyless Go on the Smartkey...
"If you do not intend to use a key for an extended
period of time, you can deactivate the
KEYLESS-GO function of the SmartKey. The
SmartKey will then use very little power,
thereby conserving battery power. For the
purposes of activation/deactivation, the
vehicle must not be nearby."
The reason why the car must not be nearby has been explained to you several times now. If you are unable or unwilling to accept correct answers, then I (we) have nothing more for you.
2016 E350 Sport
back on topic...
stevil555, please let us know if you have tested the battery in your keyfob and whether replacing the battery has solved your issue.
Regardless, just change the key fob battery. I usually have a small supply of them from eBay. They normally only last 3-4 months for me. Not sure if it's because of other keyless go keys that I have or I just change them whenever I get a battery low message. When they're new, battery voltage is in the 3.24-3.26 range, when the battery low message pops up, they're down to about 3.06. I did let it go once for a little while and the message stopped popping up after a while. When the key battery in the fob is dead, it won't start the car and you have to use the rfid chip in the key to start the car which doesn't require any power.
Change the battery and report back. Make sure you use fresh ones, sometimes the ones in the local stores like CVS, Target are old and half dead.
"The system works by having a series of LF (low frequency 125 kHz) transmitting antennas both inside and outside the vehicle. The external antennas are located in the door handles. When the vehicle is triggered, either by pulling the handle or touching the handle, an LF signal is transmitted from the antennas to the key. The key becomes activated if it is sufficiently close and it transmits its ID back to the vehicle via RF (Radio frequency >300 MHz) to a receiver located in the vehicle. If the key has the correct ID, the PASE module unlocks the vehicle. "
The complete text is available here:https://en.wikipedia.org/wiki/Smart_key
The warning came on about 6 weeks ago, I haven't replaced the battery in the key fob yet, I want to see how long it will work before it dies (I keep a replacement battery in the glove box for that eventuality).
I don't know how old the battery in the key fob is as I bought the car used about a year and a half ago and haven't changed the battery yet.
It has certainly lasted more than a year.
