C450/C43 AMG
Engine Data Screen Accuracy
Old 09-18-2018, 05:26 PM
Bueller178's Avatar
Polar White C43 Sedan
So I was watching the engine data display screen on my 17 C43.
I was surprised to see that full throttle pulls only showed a max of around 325 Tq and 275 hp.
Anybody seen better numbers? Should I be seeing a full 362 HP and 384 Tq?
I got walked by a C400 a few weeks back which I figured was chipped but now that I see these numbers, could I be running down on power?
Signed,
Curious George
Old 09-18-2018, 07:07 PM
ShakyTom's Avatar
C43 AMG Coupe
Have often seen the gauges maxed out - maybe your car is in a 'soft limp'?
Old 09-18-2018, 09:01 PM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
Signed,
Curious George
U r in limp mode
Old 09-19-2018, 08:58 AM
Bueller178's Avatar
Good to know.
Time to see the dealer.
Old 09-19-2018, 09:04 AM
Dieseldan9's Avatar
yes do u have a PE exhaust because if the valves are malfunctioning that could cause it.
Old 09-19-2018, 09:05 AM
Bueller178's Avatar
Whats interesting is the low/mid range seems to be "normal" based on my butt dyno, but it's the top end that is soft and the power gauge shows losing power but there are no other messages on the dash or any service notes in the menu. I would have figured it would have a message if it was in an official "limp mode".
I do hope however there is something wrong because I need more speed. Lol
Old 09-19-2018, 09:06 AM
Bueller178's Avatar
Yes I do have the PE and it seems to be loud and pop normally.
Old 09-19-2018, 09:08 AM
Bueller178's Avatar
Attached a short video showing full throttle and a gear change.
File Type: mov
Old 09-19-2018, 09:12 AM
Bueller178's Avatar
And another pull
File Type: mov
Old 09-19-2018, 09:17 AM
Dieseldan9's Avatar
sounds normal, just an idea might not be the cause but I have heard that happening a few times with the valves causing soft limp.
Old 09-19-2018, 09:31 AM
Bueller178's Avatar
The car sounds normal for sure, it's just not showing full power (assuming the gauges are correct) and the car does seem to drop off power in the higher revs.
Old 09-19-2018, 09:37 AM
Bueller178's Avatar
So just to clarify, there is in fact a "soft limp" mode that cuts some power?
Old 09-19-2018, 09:48 AM
Dieseldan9's Avatar
yes I will look for the thread
Old 09-19-2018, 09:50 AM
Dieseldan9's Avatar
wrong link see below
Old 09-19-2018, 09:51 AM
Dieseldan9's Avatar
https://mbworld.org/forums/c450-c43-...functions.html
Old 09-19-2018, 10:40 AM
HTXgearhead's Avatar
2018 C43 sedan
Signed,
Curious George
The numbers are by no means accurate, but they should max out at some point through the rpm range.
Like Dan mentioned, you could be in limp mode or you may have the problem I had, a boost leak. I could hear a hissing noise when I got on the throttle. My car was only making 7 psi because my intercooler was not connected properly from the factory.
When you get the chance, take your engine cover off and inspect the hoses behind the radiator, make sure they are all tight, especially the gasket from your manifold to your intercooler.
Old 09-19-2018, 12:23 PM
Bueller178's Avatar
The clamps seem tight (the ones I can reach) so I've gone to the dealer and they said they will need to test drive it.
Fingers crossed they find the problem quickly.
And thanks for the link DieselDan
Old 09-19-2018, 12:49 PM
Dieseldan9's Avatar
NP glad I could help.
Old 09-19-2018, 03:34 PM
Bueller178's Avatar
So the tech says there is no such thing as soft limp mode and he wasn't sure if the gauges should go full power.......Ugh.
He was going to do a bit more research but I suspect not much will happen as a result.
Old 09-19-2018, 04:26 PM
RichardCranium3's Avatar
'19 CLS450
"Soft limp mode" is more of the defacto forum term. What's really happening is a non-critical operation code is being thrown in the background, but as the doesn't "technically" effect operation, it doesn't throw a CEL. It's silly, but if it's actually the case, the tech should see a code on record related to the PE operation.
Old 09-19-2018, 05:28 PM
Bueller178's Avatar
Does anybody have a short video of a stock C43 gauges going full power?
Cheers.
Old 09-19-2018, 05:45 PM
ShakyTom's Avatar
C43 AMG Coupe
Keep in mind this is showing kW, but is pegged at 270 most of the video which is 362 hp.
Old 09-19-2018, 08:40 PM
Bueller178's Avatar
Great Video.
Mine doesn't get anywhere near that. It wavers on the way up and then TQ drops off a lot just before the shift.
I'll take a longer video shortly.
Old 09-20-2018, 12:33 AM
Arian Mosazadeh's Avatar
C43 Amg Coupe
If the car was sitting for a while at some point, maybe try taking the battery out of the car, charging it fully, and reinstalling it after resetting the ecu. This worked for a friend of mine.
Old 09-20-2018, 12:05 PM
2018 C43 sedan
And another pull
Your hp bar is not even hitting 300, clearly something is not working properly. I wouldn’t try to self diagnose. Set a service appointment, get a dealership loaner car, and simply tell the to fix it. That is what they get paid to do.
Quick Reply: Engine Data Screen Accuracy
