C450/C43 AMG
C43amg how to reset oil change indicator
Old Oct 3, 2018 | 11:01 PM
lou7777777's Avatar
2018 C43amg,2012 CLS 550, 2004 Chevrolet SSR, 1934 Chevy street rod
I have tried this:
Trip indicator
Hold phone answer, phone hangup, OK at same time
I get loud "clang" but no change in DIC indicator
How do I reset oil indicator in the C3amg?
Old Oct 3, 2018 | 11:09 PM
C43Ayemgee's Avatar
2018 C43 AMG
1. Turn the ignition to position 1 (one position before starting the engine).
2. Press the system selection button (house icon located on the left of the steering wheel) repeatedly until the menu item TRIP is highlighted in the multi-function display. Within 5 seconds, press the OK button.
3. Press and hold phone button and then within 1 second press and hold down the OK button. Hold for 5 seconds then the workshop menu will be displayed "Vehicle data, Dynamometer Test, Change Brake Lining, ASSYST PLUS and Head-up Display".
4. Press the DOWN arrow repeatedly until ASSYST PLUS is highlighted and confirm with the OK button.
5. Press the DOWN arrow to highlight FULL SERVICE and confirm with the OK button.
6. Press the DOWN arrow repeatedly until CONFIRM SERV is highlighted and confirm with the OK button.
7. Specifiy engine oil used with the UP arrow and confirm with the OK button.
8. Press the DOWN arrow repeatedly until YES is highlighted and confirm with the OK button.
9. Press the DOWN arrow repeatedly until CONFIRM is highlighted and confirm with the OK button. "Full service completed" appears in the multi-function display.
10. Press the BACK (curved left arrow) button repeatedly until the standard display (total distance) appears in the display.
11. Turn the ignition off and then start the engine to verify the indicator has been reset.
*Close all doors, windows, hood and trunk when performing reset
Old Oct 3, 2018 | 11:13 PM
lou7777777's Avatar
Which phone button...or both phone buttons?
Old Oct 3, 2018 | 11:17 PM
C43Ayemgee's Avatar
2018 C43 AMG
The Accept call button, Top button
Old Oct 3, 2018 | 11:32 PM
lou7777777's Avatar
As I was experimenting with the buttons....when I did one of the procedures that didn't work I would get a loud "clang". Does that have. any meaning?
Old Oct 3, 2018 | 11:59 PM
Jml0717's Avatar
2018 AMG C43
How do you do this if you have the push start ignition? What would be position 1?
Old Oct 4, 2018 | 12:30 AM
lou7777777's Avatar
C43Ayemgee was very helpful and what he told me worked on my c43amg. The START button, like the KEY, has three positions. If you push the START button or turn the KEY one position, that is where you want to be to do the reset. Is this confusing?
Old Oct 4, 2018 | 12:31 AM
lou7777777's Avatar
I should have said my 2018 C43 amp.
Old Oct 5, 2018 | 08:50 PM
Jml0717's Avatar
2018 AMG C43
Would that be by pressing the Start button without pressing the brake pedal?
Old Oct 6, 2018 | 12:09 AM
lou7777777's Avatar
Yes. If with key, go to position 1....don't step on brake or anything else. If with button, push once...don't step on brake or anything else.
Old Jun 21, 2026 | 11:22 PM
AMGMerc's Avatar
They didn’t mention you have to pop the push to start cover off and enter key manually
