S-Class (W222) 2014-2020
Quick Climate Control Settings?
Old 03-14-2019, 02:00 PM
tkelley.EClass's Avatar
2014 E350 Sport (sold), 2015 S550 Sport (sold), 2018 S560 Sport (sold), 2018 GLE43, 2014 E550
So my wife's W212 E class has the coolest climate control settings. Want air to blow on your feet? Smack the lever down a few times. Want it to defrost and blow from the front vents? Smack that baby up a few times and you're in the new mode like that. Want it off? Press off! So my questions...
Is there a shortcut button for off?
Is there a shortcut way to change which vents are blowing air (IE: feet only mode, feet and front vents, front vents only, etc.)?
Old 03-19-2019, 10:45 AM
I'm guessing the answer is no which is unfortunate. I guess I'll have to make sure my next MB has MBUX which I hear resolves most the complaints people have with COMAND...
Old 03-19-2019, 10:08 PM
obwielnls's Avatar
2014 S550
I really can't answer your question because I keep mine set on auto and 72 degrees. I know that a lot of people "fiddle" with their AC a lot for some reason but I find the Mercedes ACC to be excellent and I never have to adjust it. I live in a place where the temp varies a lot even between morning and afternoon and still don't have to touch a thing. I can tell you it's not designed to be operated manually.
Old 03-20-2019, 07:16 AM
Auto doesn't get the job done when its 5* some morning's so unfortunately I do have to manually tell it what to do sometimes...
Old 03-20-2019, 07:09 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
My only gripe is there is no quick way to "sync" the left and right side temperature settings when no one is with me.
Nice Ride (03-20-2019)
Old 03-20-2019, 11:55 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
It would be nice if the car would default to Sync to Driver every time the car is started, or with all this technology, if no one is in the passenger seat or rear seating, that it would sync to Driver.
Old 03-21-2019, 07:47 PM
obwielnls's Avatar
2014 S550
What does it not do?
Old 03-22-2019, 12:09 AM
Nice Ride's Avatar
Angry
If you have Sync Set. All temps are the same, even if you have Quad Settings Front and Rear. As soon as someone (passenger front or rear) raises or lowers the temp, it will remain that way until you SYNC again. So, unless you check, the rear could be running say 65, and you are raising the front to stay warmer. So the front and rear are fighting to keep the temp correct for each area.
Old 03-10-2020, 06:17 PM
LAWYER2's Avatar
15' W222
So is it true, there's nothing that can be done about this? I literally have to go through like 5 different swipes and taps just to turn this MF off. Sadly, this, plus the eco start/boost are the most annoying features on the car
Quick Reply: Quick Climate Control Settings?
