Need Help with Codes and No Acceleration
Old 04-17-2019, 01:02 PM
CourtneyW's Avatar
2011 ML350 BlueTEC
Hello, gutted the DPF a few months ago. Ran fine up until a week ago. Out of the blue, I lost acceleration. ML pulls out of driveway, accelerates a little but when I press the accelerator to the floor it wont go past 3,000-4,000 RPM. Husband removed the DPF and blew compressed air through the lines that the DPF sensor connects to, black soot came out. The DPF is still hollow. I replaced the DPF pressure senson, air filters, fuel filter. I will post pictures of the codes my OBD2 is pulling up. I also noticed in the diagnostic section on the reader the EGR read 0 (will post picture). Removed the EGR last night and I am cleaning it now. I pulled off the turbo actuator a few days ago and all wires look intact. What am I missing? I cant figure out why its not accelerating and I dont know what to check next if cleaning the EGR doesnt fix it? Any help or advice would be so greatly appreciated!
Cheers,
Courtney
Old 04-17-2019, 01:07 PM
CourtneyW's Avatar
2011 ML350 BlueTEC
More Pictures
Old 04-17-2019, 01:49 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Blutetec Diesel vehicles do not have "P" codes, they have 6 digit numbers.
Old 04-17-2019, 02:09 PM
CourtneyW's Avatar
2011 ML350 BlueTEC
This is my husbands OBD2 Reader. This particular reader is not designed specifically for Mercedes. I thought the P = Powertrain and the codes were pretty generic. I understand I'm not receiving true Mercedes codes. Can these codes not pinpoint a problem area?
Old 04-17-2019, 02:46 PM
Here are the codes.
You should get a scanner reader if you intend to keep your vehicle.
Amazon Amazon
File Type: pdf
Old 04-17-2019, 08:34 PM
CourtneyW's Avatar
2011 ML350 BlueTEC
Thank you so very much! Do you recommend any particular scanner? Yes, I do need a better scanner but have no clue which one is best for this vehicle.
Old 04-17-2019, 08:36 PM
CourtneyW's Avatar
2011 ML350 BlueTEC
I replied before I saw the Amazon link! Thank you again, I will be ordering this scanner.
Old 04-18-2019, 03:42 AM
Make sure it is that particular scanner.
CourtneyW (04-19-2019)
Old 04-19-2019, 11:48 AM
CourtneyW's Avatar
2011 ML350 BlueTEC
Think I figured it out... Turbo Actuator. I noticed when I turned my car on I could hear the sound but the actuator was not moving (I saw a tiny jerk like it was trying to move). Contacted Alec (www.turboactuatorrepair.com), extremly helpful and honest gentleman! Removed the unit, took pictures and emailed them to him. Nothing appears to be wrong with the gears or the circut board. So, with it being a holiday weekend (husband's out of town and I'm stuck at home with a non working vehicle).... I'm tempted to buy an actuator off Amazon, prime shipping will have it delivered Monday. Hopefully I can mail my actuator to Alec Monday morning and cross my fingers that the one from Amazon works. Has anyone purchased one from Amazon or Ebay? I figure worst case senario, if it doesnt work I can call Amazon to set a return/refund up. Contacted the Malone authorized dealer in Dallas to inquire more information about the tune... hoping to get my car to them in the next 1-2 weeks.
If I can get this problem solved, next up is solving another oil leak (I think its the PCV valve and the gasket that sits between the oil filter housing/engine block.) If anyone has any feedback on purchasing an actuator off Amazon or Ebay feedback would be awesome! Thanks!
Cheers,
Courtney W
Old 04-20-2019, 06:58 AM
texterted's Avatar
ML420 W164 (2009)
Like you said, you can always send it back for a refund.
Worth a shot... good luck!
CourtneyW (04-20-2019)
Quick Reply: Need Help with Codes and No Acceleration
