Airmatic long term
Airmatic long term
Hopefully will be picking up an E55 next week. Obviously the Airmatic suspension is a common issue these cars have. Been searching and searching to find how many miles people have been able to put on their factory suspension setups. Haven’t been able to find a thread in regards to this. I know every car is different and the system could have issues at any age/mileage. Trying to be optimistic here. Thanks in advance.
https://mbworld.org/forums/market/718386/page1
That is because it varies with each owner. There isn't a set years or miles that this suspension lasts. Some have had issues, some haven't. It's a crab shoot.
Cj0311 (04-18-2019)
SPONSOR
2007 Mercedes E63 AMG
my E63 had its airmatic shocks and bags replaced at around 70k and then at 110k. now i am using arnotts so they will come with a lifetime warranty.
replaced my compressor and filter at 98k...honestly wasn't sure it even needed replacement as the issue was related to something else entirely. one of the pins for the connector to airmatic computer was broken in the connector.
Cj0311 (04-18-2019)
I did coilover conversion 3 years ago... BC Racing. Total cost $2K include control arms, installation, alignment...
I have my car for 10 years only issue or fail is Water pump then everything else is just regular maintenance. It has 118K miles now.
The following 2 users liked this post by CharlyE500:
Cj0311 (04-18-2019),
E55amg0220 (05-03-2019)
86000kms or 54000miles and I have had to replace both front shocks, they went about 5000miles within each other. 2005 CLS55
Cj0311 (04-18-2019)
Cj0311 (04-18-2019)
Changed my 2006 E55 right front in 2015 with 120k, did both rears last November at 170k and left front in December. Arnott is the way to go for saving money cause OEM costed me $800 for one front strut and that’s with 30% discount from dealer. Rock auto have the best price for Arnott. Good luck with your car purchase!
keep in mind browsing the forums you will always find the people posting about the issues which creates the illusion that it is far more common than it actually is. hundreds of thousands of these cars were made and not all of them will fail...i'm close to 100,000 miles and no issues yet!
Arnott says on their website that the life expectancy of air springs / struts is about 100,000 miles. Sure, you may be able to go longer than that but what happens if one of them fails and you're far from home? If you plan to keep your car long term, the best thing to do would be to treat it like a maintenance / wear item.
I've got Arnotts at all four corners, Installed the fronts at a little over 200k miles, rears were on the car when I got them so unknown mileage but they are the Arnott designed bags. One of my brand "new" rebuilt front struts sprung a leak a couple months after I got it. They swapped it out no problem. Great company and I'm very satisfied with their products so far.
That being said, I love the system and will continue to replace it.
'99 and '05 E55 AMG
I made it to 99,000 miles when the rear air springs started to leak. I went and replaced all four air springs plus rebuilt front and rear suspension all the way around. FWIW, I'm about to replace my rear tires that now have ~33,000 miles on them. I would worry more about bushings and ball joints than the air springs. However, I'm a believer in preventive and pro-active maintenance.
Cj0311 (04-23-2019)
just buy the car expecting them all to fail, factor that into the original price you're paying for the car, and that way things can only work out great!
Look nothing lasts forever on any car, at some point things will either fail or break, thus requiring it to be replaced.
