Speed limiter - what actually is it? 175 or 186 mph
Theoretical question- I always thought the W212 E63 was limited to either 155 mph / 250 kph or 186 mph / 300 kph. The former for the non "S" and the latter for the "S".
However - in my '16 the limit seems to be 175 mph.
I know the speedo may not be 100%, but that's off the "wrong" way by 10 mph (which I think is HIGHLY unlikely) or 20 mph the "normal" way (which I also think is unlikely, 13% error). Checking the speedo against GPS speed (on radar detector) shows less than 1 mph off in speeds up to 100 mph.
Confused.
Confused.
175 is the highest I have seen in my 2016 Sedan. That being said, I was starting to run out of room - so did not have the luxury of waiting to see if it would still climb.
Received 2,143 Likes
You guys run this fast on an airstrip?
cotmfk (05-29-2019)
cotmfk (05-29-2019)
It's 186mph stock on my car 100%
After all the upgrades and tune to remove the speed limiter I did I hit 218 mph ...ran out if road
Not saying you did not see 218 on the speedo. Any chance you changed the gearing? Or put on aftermarket wheels?
Interesting, wonder why?
I thought for a second that maybe because I'm a wagon I get 175. But you have a 2016 sedan. Same year, same limiter.
Gearing is stock, wheels were stock as well..I do have a set of 20inch Rohanas but never went over 140-150...just dont trust them as much as I do with the stock ones.
How accurate is a speedometer after 180mph?
In the old days there was <5% error rule, but with electronic speedometers it's a matter of what is programmed in as the error. Most tests today show they are very accurate, usually less than 2 kph (so about 1 mph) and constant.
In my case I used the GPS on the radar detector to check the speed at lower speeds and it's dead on, zero error.
