Need help with intake ideas with OEM look - 55
Old 07-17-2019, 12:41 AM
anton28's Avatar
2014 Rover, 2014 Viper
I want to get more air flowing but I don't want to get rid of the factory airbox look. Are my only options K&N filters and spacers? Is it worth running new pipes down to the grill from the OEM air box?
What can I do but still retain the OEM look?
Old 07-17-2019, 06:38 AM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Just leave the OEM airbox and ducting. Aftermarket variants rarely flow more and it often ends up less. I don't know if there was ever a consensus on the spacer kit but the OEM intake is generally quite good.
Old 07-17-2019, 03:30 PM
AMGPilot's Avatar
2004 E55
Have you actually measured the flow on your air boxes? I can guarantee that you are not out flowing them
leave them alone, there are better ways to spend your time and money
Old 07-17-2019, 04:28 PM
anton28's Avatar
Great feedback guys. I was not sure of the factory box's capabilities or restrictions. I'm about to tune the car and add an 80mm pulley. Upgrading the factory box was an intuitive decision based on everything else I have built in the past. Seeing all the modified 55 engines online with the crazy intake setups made me belive, the factory box was very restricted. It sounds like that might not be the case.
Old 07-17-2019, 04:37 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I'm sure that Mercedes Benz had their best engineers, thinking long and hard about getting the best air flow into that supercharger.
This can not be solved by simply added a new air filter, airboxes etc.
Old 07-17-2019, 04:49 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
If your mildly modding the car then leave the factory box, if your going crazy FBO then that’s a different story .
Old 07-18-2019, 06:47 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
There are some green filters that are supposed to be good. K&N's let in a lot of fine grit. I went back to stock
Old 07-18-2019, 11:33 AM
anton28's Avatar
Very good point.
Old 07-18-2019, 08:13 PM
E42AMG???'s Avatar
E420
Stay stock unless putting bigger tb
Old 07-21-2019, 05:39 PM
anton28's Avatar
Thanks for the input everyone. Staying stock!
Old 07-22-2019, 01:39 PM
CDC55AMG's Avatar
CLS55AMG
I went with Weistec drop in air filters, they are thinner than stock variants so you do not spacers in order to keep the filters from blocking incoming air flow.
Old 07-22-2019, 03:47 PM
AMGPilot's Avatar
2004 E55
The Filter doesn't block air. Never has and never will
Old 07-22-2019, 04:31 PM
tw2
tw2's Avatar
Doesn't the stock filter hang down 3/4" or so into the incoming air? Maybe I made that up.
Old 07-22-2019, 04:33 PM
CDC55AMG's Avatar
CLS55AMG
This is what I was talking about:
Weistec air filter
Stock paper filter
Old 07-22-2019, 05:46 PM
AMGPilot's Avatar
2004 E55
Weistec air filter
Stock paper filter
Yeah? and how does an air filter work?
That is not a restriction Fluid dynamics doesn't work that way
Old 07-22-2019, 08:11 PM
tw2
tw2's Avatar
Please be kind enough to explain this. I was under the impression fluids generally don't flow the best with solid objects jutting into their path.
Old 07-22-2019, 08:29 PM
AMGPilot's Avatar
2004 E55
That's not a solid. that is filter element.
Old 07-22-2019, 08:33 PM
tw2
tw2's Avatar
Yes and air from the intake snorkel runs straight into the side of it before making an eddie and going around and through it.
Old 07-22-2019, 08:45 PM
AMGPilot's Avatar
2004 E55
only that’s not what happens
Old 07-22-2019, 08:47 PM
tw2
tw2's Avatar
You are oozing technical information today. Please refer to post 16.
Old 07-22-2019, 11:58 PM
CDC55AMG's Avatar
CLS55AMG
Filter element or not wouldn't it still increase turbulence or disruption of the incoming air flow hanging into the air intake tube vs not at all?
Quick Reply: Need help with intake ideas with OEM look - 55
