SL/R230: Temporary Power Loss in SL 55 AMG 2002
My SL 55 AMG 2002 has done about 16k miles. I am facing two problems.
Firstly temporary power loss at random. I would say around 10% of the time when I push the pedal down it does not accelerate as fast as it is supposed to. If I stop the car turn it off and then on again the problem resolves itself. Any idea what could be causing this? It gets fixed automatically upon restart. I tried a new accelerator pedal thinking that's the problem but it did not solve the problem.
Secondly the fuel consumption is almost double of what it should be. All regular maintenance has been done recently. I feel both the problems may be connected.
Thank you
Thank you
hope that helps,
Chris
hope that helps,
Chris
my indy found metal shavings in trans oil pan so we replaced the trans with a used one low mileage.. he suggested this would be a better alternative than trying to track down the issue within the trans. usually good service from them but they were off on this problem.
imagine my shock when I was dead on the side of the road a week later still no power to the wheels!
I decided to pony-up and take it to the dealer the next time. turns out the TCM transmission control module ($2K) was going bad they replaced it and ive been great ever since.
My problem is not 1% power. The problem is that the supercharger goes offline. You still have power but not the full power. Problem fixes immediately when car is turned off and on.
my issue would be fixed after restarting when stalled on the road. eventually restarting did not resolve the issue
Will have a look at the transmission module as well
Have you checked for stored codes?
Have you checked your IAT?
Are you actually monitoring boost? or are you just assuming that the supercharger is dis-engaging?
There are only 2 things that come to mind that shut off the supercharger ... High IATs or malfunctioning bypass throttle. ... the second will store a code.
Please report back with codes or that you have checked them and have found none.
Also, please indicate HOW you are confirming that the supercharger is not working (monitoring boost? monitoring clutch signal?)
How have you confirmed that your charge cooling is working? (have you observed steady flow when the pump is running?)
Have you checked your IATs ?
We have checked for stored codes. The recurring code before changing the charge coolant pump was:
P2027-0-01 Y31/1 (EGR Vacuum transducer) (P0403), short circuit to positive
We changed both the charge cooling pump AND the secondary air intake pump
The few times we tried to monitor we did not have the said power loss therefore could not actually check if supercharger is dis-engaging. This assessment is from actually driving the car and feeling the boost in correlation with the RPM. The power loss is not on every drive. Sometimes it will come within first 2 minutes of driving the car and other times it won't come for days.
We replaced the charge cooling pump with a brand new one as recommended by this forum. The flow is steady when pump is running and we checked the Intake Air temperature few days back and there seemed to be no issue in air temperatures. All seemed in normal ranges.
Let me check all the things you mentioned again and get back to you with most recent data. As data I am giving you is before we changed the charge cooling pump. We changed the pump few days back and I have been road testing it since then to see if the problem reoccurs. Just in the past 2 days I have found that the problem is still there. I will connect the scanner today and get back to you with what codes are showing up now.
HTH,
Chris
The previous error showed up again:
We monitored the temperatures again while driving and while experiencing power loss. There was no indication that the Secondary Air Intake pump or Charge cooling pump were not working. They seem to be working fine.
Do you think it could be a connection with the ECU that could be at fault? Quite possibly the connection between ECU and Secondary Air intake pump?
Chris
older models tells nothing ,just loose the supercharger for short time .
Do we have a solution for this?
I've been battling for one year now. Can't seem to get rid of the problem.
I even laid a bypass cable from ecu to the egr Actuator to be sure there's no short or oil in the cable
Any help is greatly appreciated!
Kind regards,
Robert
