Post your ML / GLE lowered pics and specs!
Not sure why there isn’t a lowered w166 thread… but there is now. Post your ML or GLE and how much it’s lowered front and back and also tire and wheel specs. Let’s see what’s out there!
I’ll start.
2014 ML550
21x10 AMG wheels and 295/35r21 tires
lowered 30mm front and rear in this pic.
Oem air suspension and lowering module.
I’ll start.
2014 ML550
rapidoxidation (03-23-2022)
I like the thread idea, but I think the original poster and others should also mention the hardware/product (H&R springs vs. reprogrammed air suspension, etc.) used to achieve the lowering, not just the measurements.
Here's my contribution:
2016 GLE350 4MATIC
20x9 AMG wheels on 265/45 20 tires.
Lowered with H&R Sport Springs 1.25" up front and 1.75" in the rear.
Before and after:
2016 GLE350 4MATIC
Before and after:
The following 3 users liked this post by gearFX:
I’ll start.
2014 ML550
I’ll start.
2014 ML550
mike919 (03-23-2022)
2016 GLE350 4MATIC
Before and after:
2016 GLE350 4MATIC
Before and after:
What's the camber like? Hows is the ride stiffness before / after?
The ride stiffness is definitely acceptable, but I am also one of the few people who installed adjustable aftermarket sway bars on my F-150. The ride is still great if your roads are in decent shape, and obviously feels more secure and buttoned down on the highway and curves. If you encounter a pothole, railroad tracks, or major dip it will certainly compress faster and harder than with the stock springs, but I would never revert to the OE springs again (too floaty with too much head bob).
There is definitely more noticeable camber than before but not an extreme tucked "stance" look. The front required Mercedes' front camber bolt kit to get the alignment close to spec, but there's not much you can adjust for the additional squat in the rear. Here's another angle showing the modest camber after the springs.
Don_CA (03-25-2022)
2016 GLE350 4MATIC
Before and after:
2016 GLE350 4MATIC
Before and after:
gearFX (03-30-2022)
at -30mm mine has a lot of camber in the rear and just a little bit in the front. I’m going to adjust the rear when I have time. I’m not too worried about tire wear as it’s only lowered about an inch from stock in sport mode and about 1/2” in comfort mode. I’ve now got it set at -30mm rear and -25mm front for a more level stance. In comfort mode it goes almost back to the stock sport mode ride height which is still super soft. Sport mode is now stiffer than before. Mine was pretty low from the factory so -30mm (less than 1.25 inches) looks really low.
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I’ll start.
2014 ML550
I’ll start.
2014 ML550
I lowered the rear only on both this truck as well as my GC SRT. On the SRT, ride quality didn't change much, but the Benz definitely has a harsher time of it over nasty bumps.
RazaGLE350 (Today)
Oh, and one thing you'll find on this site. MB owners "generally" don't like mods, present company excepted. I've done ***** to mine some wouldn't do to a farm animal *wink*
Good point, I stand corrected.
As well, "Truck" would also imply a robust, tough vehicle. Definitely not the case here
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Doubleredrolex (04-07-2022)
I use the suspension lowering module for short distance driving. If I need to go long distances, I return it to the stock values. Then I don't have any problems with the camber because the wear is insignificant.
I am happy with my mwmods.com module.
What wheels setup is that if you don’t mind sharing? (Wheel size? Width? Staggered? Offset? And tyre side-wall height?) the look of the rims and the wheel fitment is great!
