MWMods Lowering Module
I inserted the Hand Held Lowering Module into the OBD2 connector and got the message on the media screen that I was in factory mode.
I set it to LOW and it dropped 40mm (just under 1 finger gap). I set it to custom before I changed anything and it set to 32mm lower (1 Finger gap)
I set it to factory and it went back to a 3 finger gap above the tires.
The floating body feel is gone when riding 20mm lower.
I'm going for almost a 2 finger gap for everyday use.
You can adjust from a (+40mm)-(-70mm) in Custom mode
$500 US dollar
Definitely worth the money if you want the look!!
The mud flaps you see have been painted body color (Anthracite Blue) and then clear coated.
Read the description under each picture.
The Hand Held Lowering Module and instructions
Factory Height
Factory height
Custom 32mm lower
Custom 32mm lower
Setting on Low 40mm
Setting on Low 40mm
does the low ride setting feels like factory comfort or closer to sport suspension settings?
So it's sorta on the fly but not while traveling. I find the hardest thing to do is just pulling it out of the OBD2 connector when finished. The Comfort setting in the dash stays the same. The comfort level felt in the seat of your pants goes down as you lower the vehicle past a certain point (the point the floaty boat feel goes away). The lower you go the harsher the ride as with any vehicle but by no means is unacceptable or unexpected.
edit: I believe you have Magic Body Control not Airmatic suspension. Check and see if it works on your car.
$500 US dollar
1 finger is about 3/4 inch.
25mm or about 1" which is perfect
25mm or just over 1 finger
Current Custom setting I put in - to change settings move Left or Right on media knob to select front or rear then up and down on media knob to adjust reading
This is the OK message you get after the Security Access window
It's checking itself against the VIN number which was preprogrammed into the HHModule
Custom settings from module designer - Can be changed
Select this when you want to change the Custom settings - Push down on media knob to select
If you want the preset Low setting (-40mm) then select this by pushing down on media knob
If you want to go back to the Factory setting select this window and push down on media knob - Factory is about 3 fingers or 2.25" gap
Select this window to put vehicle height at your preferred Custom setting
Hey, I just checked, on my unit at least, the default Low was at -32mm. I've increased the height a bit to -27mm both front and rear. I am not noticing a massive difference (obviously), but it feels a wee bit smoother whilst still avoiding the boat-y feeling.
Here are two photos, at -27mm:
Front:
Rear:
This thread discusses suspension lowering module from MWMODS company.
Please do not be misled by the "cheapness" of your service, considering the obvious advantages of our product and team.
Suspension lowering module can:
- unlimited times to change the suspension height
- return the height to the factory, what will help maintain the dealer's warranty
- set the ideal height separately front and rear axle
- setup takes 30 sec, no wires, pc or other unnecessary devices
We have been known on this forum for 5 years, our managers are easy to communicate with, professional and always loyal to our customers.
Hoping for understanding, mwmods.com team
I put the ride height back to factory when I dropped it off.
That is a very convenient feature of this module is to be able to go back and forth when needed. Same on the engine tune module (Factory or Tune Programming). More on that module later.
Also, if I were to compare with Renntech, why are they so much more expensive (plus I not sure if I can even find them in EU), on what appears to be a very similar service? I'd love some input from people with mwmods past experiences (mostly reliability, engine codes etc) before I would take the plunge.
Dear Ninja
As for price or cheapness or whatever, as a client, I always prefer to have the prefect balance between paying the least amount of money combined with ease of use/coding "i.e.: module vs coding, same day cable remote coding vs major equipment , etc.". NWMODS have the perfect balance in my view and the idea of modules is just brilliant and convenient.
Happy to do our best for you! 🙏🏻💪
After driving around and playing with different ride heights I have found -20mm to be my preferred daily driver setting. It's low enough to make a difference but not so low I hit parking spot stops.
I had a friend of mine say "It looks lowered". I was so proud.
Love this upgrade!
When working under the vehicle remember to raise the vehicle using the button in center console. Put it in the fully raised mode. I was able to work on the exhaust flaps with no problem this way.
At the moment there is a promotion when you buy lowering module + stage1,2 ECU tune you save up to 300usd
After a bit of frustration, the update worked as promised.
So there supposedly sending another that * should work* ( his words) ...super confident lol
Ill update next week when i get it....
