C63, C43 AMG (W206) 2023 -
W206 C43 AMG Wheel Fitment Guide
Old Apr 14, 2023 | 06:30 AM
alexasa's Avatar
c
I'm just going to get this started and hopefully others over time will add their own experiences to the thread. I initially thought brakes, rotors, suspension, etc. would have been shared with the outgoing W205. I am wrong on all accounts. Here are the factory equipped options/specs.
Rear of RZX wheel option and Part Number:
Picture of OEM bolt. 45mm length post collar/head. Smooth/tapered shaft found on other Mercedes Benz models.
Picture of front calipers - different than W205.
I have ordered some OE replacement bolts (from another MB model) to run a 6mm spacer and will post more once I confirm it is the correct equipment. 6mm upfront is perfect for OEM ride height. I'd probably run a 8mm in the rear if I could but for now I'm just going to run the 6mm on all 4 corners.
Stay tuned for more.
Old Apr 15, 2023 | 07:17 AM
W205C43PFL's Avatar
Picture of OEM bolt. ~39mm length post collar/head. Smooth/tapered shaft found on other Mercedes Benz models.
Thank you! Glad we have a similar thread like the W205. Excited to see everyone's build and to customize things to make it uniquely their car.
Old Apr 21, 2023 | 07:35 PM
alexasa's Avatar
c
Going back to what a very valuable member has shared - I believe these are the correct lug bolts to run for a ~5mm spacer on the 19 or 20 inch factory wheels. I have had to order a couple different bolts to get to this place.
https://otisincla.com/product/14mmx1...th-70mm-black/
I should be able to share, visually, what 6mm on all 4 corners looks like tomorrow.
It's difficult to recommend alternative sizing for aftermarket wheels. The tire sizing really limits to slight manipulation on the front with something like 19x8.5et45 w/ 245/40/19 (this same thing can similarly be ran with 20's)
The rear almost needs to stay at the 9.5 width and can go down to et53 through OEM offset at et61.
To upsize the rear you'd need to run something like a 19x10.5et68 w/ a 305/30/19 - and I'm not sure what clearance limitations you may run into with something like that. When the c63 specs are out we should have a better idea of what we can put in the rear.
Like pretty much every 4,000 lb car that is AWD - the front end could probably benefit to have more tire. Something like a 255 should totally work in terms of fitment on this car where it was pretty much impossible on the W205 C43.
Old Apr 22, 2023 | 04:38 PM
alexasa's Avatar
c
This is stock:
This is 6mm front and rear (I'd probably prefer the 5mm upfront as opposed to 6mm and might make that change in the future):
While there is more room in the rear - I really like where the rear is. I feel like an extremely flush setup works best without as much fender gap. Without lowering the car a wheel that sits in slightly helps guise the fender gap while very flush wheels accentuates the fender gap. The front is right on the cusp of having that problem with 6mm and 5mm would overall look better IMO.
Old Apr 23, 2023 | 08:44 AM
alexasa's Avatar
c
Couple more to show the setup. You can see the front fenders flare out quite a bit all the way at the top but slim in quite a bit. If the car was lowered you could probably run pretty aggressive fitment compared to stock offset/widths.
Old Apr 27, 2023 | 12:06 AM
eatmydust's Avatar
2020 C43, 2008 E350
Do you think with lowering it, the rear wheel steering fitment could rub?
Old Apr 27, 2023 | 12:45 AM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
What brand wheel spacers, hubcentric?
Old Apr 27, 2023 | 07:09 PM
alexasa's Avatar
c
depends on how low
you don't need hub centric for this small of a spacer - wheel still has plenty of OEM hub to mount to. The 12mm's I tested were hub centric for instance.
Old May 4, 2023 | 07:44 AM
alexasa's Avatar
c
I ended up w/ 3mm front and 6mm rear - looks more balanced for me especially at stock ride height. 5x112 w/ bore of 66.56 for the spacers. The aforementioned bolts would be my pick.
Old May 4, 2023 | 09:38 AM
W205C43PFL's Avatar
Sharp
Old Jun 6, 2023 | 11:53 AM
BigBodyBH's Avatar
2023 C43 AMG Sedan
Where did you purchase the spacers from? Got a link? Would be looking to do the same to my C43
Old Jun 8, 2023 | 03:12 PM
alexasa's Avatar
c
I used these for the front. The rear spacers I used are no longer available.
Amazon Amazon
Just follow the specs of 5x112 66.56 bore and the width you want. 5mm to 7mm should be great for the rear for a subtle improvement.
Old Jun 15, 2023 | 05:37 PM
ec1c173's Avatar
c63
The previous generation has no inner clearance if you go 8.5 with higher offset than ET32. I wonder if it's different for the W206. Can someone kindly take a picture of the inner clearance for the front wheels?
Old Jun 15, 2023 | 06:36 PM
alexasa's Avatar
c
The stock wheels are already closer inboard than 8.5 et32.
Old Jun 15, 2023 | 07:40 PM
ec1c173's Avatar
c63
Yes, you're right. I am trying to check if fitting 20x9 is possible on this chassis.
Based on the info from this thread.
Stock: 18x8 ET43.1
With 6mm spacers : 18x8 ET37.1mm ( Flush )
In order to have the exact inner clearance with the 9-inch width wheels for the front. The wheel spec has to be at least 20x9 ET30. But it will be poked out 25.7mm versus the stock wheel. This spec will definitely be too aggressive for the W206. I am wondering if this chassis can get away with 20x9 ET40, which will move the wheel about 10mm closer to the strut and poke out 15.7mm more than stock.
If any of you guys can provide some pictures of the inner clearance between the oem wheels and strut/control arms, that would be greatly appreciated.
Old Jul 7, 2023 | 09:08 AM
alexasa's Avatar
c
I've been looking at aftermarket wheel options and found that Savini is the only company I could find that makes a 20 inch wheel that would bolt right up without custom offsets, etc.
These are available in different finishes, can use OEM tire sizes and would not require any spacers to have a flush look.
Old Jul 8, 2023 | 10:02 AM
paj's Avatar
paj
17 C43 AMG
Yes I found that also. Not familiar with this company/brand. Is it a good/quality wheel?
Old Jul 8, 2023 | 10:28 AM
alexasa's Avatar
c
I have heard of them but have no experience with them. They are flow formed so they should be strong/light for what they are.
Old Oct 12, 2023 | 09:16 AM
AMGsuper's Avatar
W204 220 cdi
hello friends I'm new here , I have ordered a set of forged wheels , the order is almost complete except the offset , i want to install a 20 inch wheel on a c 300 d amg line . I want it to be a complete plush look any help and suggestions I'll be very thank ful .it's a w206 .
