E300 - Engine Temperature
Hello Guys,
I need some guidance as i`m stuck.
I own a e300 petrol 2017 - Temperature gauge started fluctuating while driving - temperature was going down.
Change thermostat as it was stuck open - it improved but not by a lot.
Changed Coolant sensor - nothing changed.
Temperatures go down to 75*C while at a red light and while driving goes up to 83*C-85*C but drops when slowing down or stopping to 77*C-78*C.
It reaches 90*C but not easily.
Don't know what else to check...
Bad sensor
It sounds like the sensor might be shorting out due to some other malfunction. I know you have the same engine as I do and while the E300 is a pretty reliable car it does have its quirks. In any case I think the only way you’ll find the problem is to bring it to the dealer and let them hook it up to their computer that can test for such faults. While I’m sure it’s annoying I doubt the engine is in any immediate danger of having a “meltdown”. Good luck.
I went to the dealer as they changed on warranty the thermostat - will come back with updates/fix
So issue has been solved.
Except the mechanical issue of the thermostat - issue was only solved after rewriting/updating car`s computers, they reported that all of them were updated.
ECM,ECU,Instrument cluster etc - that sorted the bug/issue/error.
Diesel Benz (07-11-2023)
The rest were just bad reading from ecu or other computer.
Diesel Benz (07-12-2023)
best
