S-Class (W222) 2014-2020
MWMods - ECU Stage 1 tune
Old Mar 15, 2024 | 08:20 AM
Quenthel's Avatar
S560 Long 4Matic (DE) MY 2018
Hello all,
I've ordered the ECU tune from MWMods (along with the AMG cluster) and if nothing goes wrong, I expect it to arrive next week. I will update this thread with my experiences, but for now I would like to provide some additional information I got when discussing with their team before I did the purchase, in case it helps you make a decision.
I should add here that I had already ordered the Lowering Module from them a couple of years ago and I am very happy with it; I use it before service and warranty visits to the dealership.
Here are the highlights:
Q: What's the difference between using RON 95 vs RON 98 fuel? [91 & 93 US octane respectively)
A: RON 98 would produce better performance, but it would probably not be noticeable in daily driving. It is not required to use RON 98 as it would be with other tunes and using RON 95 would not create any risks for the engine.
Q: How do I best protect the engine with the tune installed?
A: Maintenance is similar but it would be recommended to change oils at 1-3K Km (0,6 to 1.8K miles) sooner compared to stock.
Q: If the engine suffers a failure, how can I revert it and is it detectable?
A: The mod should be undetectable by logs or connecting Mercedes services [not sure if they meant Xentry servers or simply Mercedes Me here]. If there is a catastrophic engine failure and the ECU is sent to Daimler for deep analysis, the tune can be detected (like with all ECU tunes). However, the tune does not disable any engine protection systems [understandable risk from my side].
That's it for now, I'll keep you posted!
Old Mar 16, 2024 | 10:12 PM
mtimmy's Avatar
W208 55 & R170 230
I had the stage 1 from MWMOD for my S63,. it feel very weird and the power seem gone down after flashing the tune.
Let me know how you feel after you flashed it...
Old Mar 17, 2024 | 12:50 AM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Well anyone who claims 0.6k miles oil change makes any difference is full of ****.
Not that I have experience with their products but that is some made up bull**** of epic proportions.
Old Mar 17, 2024 | 02:44 AM
BenzV12's Avatar
W212 FL
I hope you will be satisfied with their products but I have not heard of 0.6 miles oil change thing either and it doesn't like a plausible thing at all .
Old Mar 17, 2024 | 05:24 AM
Quenthel's Avatar
Just to clarify, the guy is not saying to change your oil at 1-3K Km, rather that you'd change it sooner by that amount, e.g. Instead of 15K Km, you ought to do that at 12-14K Km.
I still don't know if this makes any difference, but I barely do 10K power year as is.
Old Mar 17, 2024 | 06:55 AM
BenzNinja's Avatar
Former Vendor
Get a real tune instead of that "ripped damos on a $10 obd plug" junk from Belarus
so many brands that worth it all over the forum
Old Mar 17, 2024 | 07:52 AM
Quenthel's Avatar
Peter, I'd love to use your services, but I'm not in the position to do so. My garage is on the second basement of our apartment building and there is no connection whatsoever to the outside. I just don't have the luxury to leave the car somewhere for a few hours unattended where I live.
I keep you in mind when I (eventually) move to my own house in a few years time with my very own garage.
Old Mar 17, 2024 | 11:15 AM
BenzNinja's Avatar
Former Vendor
I know and perfectly understand what city-life is
You have a Hotspot solution too btw. Members always use that when they are on the side of the road with a problem so whe check and help
You will be very welcome
Old Mar 18, 2024 | 04:53 PM
Quenthel's Avatar
It was sent today, I'll get it (via DHL) by Wednesday. I won't be able to get a feel for it until the 30th (there's a small trip to Munich involved then where the car can stretch its legs).
I may visit a Dyno in the summer during my vacations, but my expectations are realistic, I doubt the car will manage to even attempt reach the advertised increased HP & torque, but it will be interesting to see what the mod is actually capable then.
Old Mar 21, 2024 | 03:27 AM
Quenthel's Avatar
I got the device yesterday. The upgrade was installed within a couple of minutes; no problems there. I couldn't resist the temptation and I took the car for a ride in neighbouring Germany.
Here are my honest impressions:
1. Revving the engine just a wee bit, made it slightly louder. That means nothing on its own of course.
2. I only had the chance to do one 0-100 Km/h acceleration test but I messed up my measurement. I have noticed a slight improvement, but I am not really sure if it's actually there, not without A/B testing it.
3. I did notice an improvement from 100-200 Km/h, since I felt that I've reached 225 Km/h faster, compared to past attempts.
4. Fuel consumption seemed to be higher, even though the dash reported ~ 11 l / 100 Km. For the most part, I've been driving in E mode, since getting to Singen from Zurich is a very speed-limited road (80 Km/h for a very long stretch), only using S for the actual acceleration tests.
5. I am not sure if I feel the (supposed) extra torque.
6. I have RON 98 fuel in the tank.
I will try to perform some more tests on the 30th.
My impressions so far are mixed. I am not sure I have experienced any significant improvement in the 0-100. In their website they report dropping from 4.5 s to 3.8 which is an improvement of 15,5%, a number that is small enough to not be that easily discernible on theory. I doubt the mod gives you +101 HP and 0.7s in 0-100 however...
On the other hand, acceleration past 100 Km/h seemed to be there, definitely more noticeable than 0-100 but not something earth shattering really. I will know more on the 30th.
I've heard that proper mods will also reduce fuel consumption on E mode, but so far this has not been my experience. Again, this is probably user error, I need to measure it properly and in an isolated manner.
So, here's my recommendation based on my initial experiences: If you need a device to be able to program and restore the ECU within 2 minutes on your own, because you don't want the dealer to know, this will do the trick. If you don't care about that, you really can't tune a car properly without a Dynamometer, a professional that knows what they're doing, and probably better air filters too. I'll update this in the near future.
Old Oct 7, 2024 | 02:56 AM
Quenthel's Avatar
Hi, I am back with an update. It's been almost 7 months since I got and installed the mod and I had the opportunity to drive the car more often and in different roads. Tl;dr, it's disappointing, if you want the extra performance, go to a reputable tuner.
I was driving in the long stretches of the italian highways (the Autostrada) last week. That gave me the opportunity to keep a relatively stable speed for a 200Km stretch with a full tank. I would take a couple of breaks, then get back to the road's max speed using full acceleration.
Here are my observations: I didn't really notice an improvement in acceleration. It might be there, but if so, it's so subtle, I can't tell. I did however notice an insane amount of fuel consumption, which was also misreported on the dash. For the 200Km spread (and just two "pedal to the medal" accelerations back up to speed), I was burning through 30 litres of fuel as reported by the fuel gauge. That's 15l/100km, however the car would report 11l/100Km.
This was unreasonable. I've managed to reach up to 7.9l/100km on this road and the consumption hovers easily at around 9l/100km for me.
I stopped a third time and uninstalled the mod, and I also did reset the statistics. After driving 100Km more or so, the numbers were far more plausible, at about 8.5l/100Km and the fuel gauge seemed to corroborate this. Suffice to say, I'll keep the mod uninstalled, turning it into an expensive paperweight, but c'est la vie.
Old Oct 7, 2024 | 03:32 AM
BenzV12's Avatar
W212 FL
Sorry to hear about that . That should be a major disappointment . A similar broken tune up happened to me in my W212 as well. In Sport Mode, when you accelerate the car starts to jolt shifting 1st to 2nd gear and it does definitely dampen your pleasure of driving the car .It doesn't happen all the time but it does happen .
Old Oct 13, 2024 | 03:08 PM
2012 merc amg's Avatar
2018 S560
I had a feeling this thing sounded too good to be true, I'm happy with the stock performance of my car, it has plenty of Power with 463HP. Don't really need anything more.
Old Oct 13, 2024 | 05:08 PM
NbyNW's Avatar
Veteran: Navy
Various
Go for RENNtech. Solid reputation. I drive mine conservatively but when needed it’s good to have. Working around traffic is a breeze.
https://www.renntechmercedes.com/ind...22-s560-detail
Old Oct 14, 2024 | 02:43 PM
Quenthel's Avatar
I feel the same. I either couldn't tell that the mod did something when it actually did, or it didn't do anything. I mentioned that I noticed a slight improvement, but that might just be bias.
In the end, I don't have many chances to do 0-100Km/h or even 100-200 for it to matter; the car never disappointed when I wanted to overtake or go pedal to the metal in the German Autobahn. I would consider leaving it there, if it worked like proper tunes, i.e. reduce the fuel consumption on Economy and go full out on Sport mode, but it doesn't do that, at least judging from my car's fuel consumption.
I've also gotten the AMG cluster mod. It works, but some of the panels do not have any data on it, I'm guessing do to the lack of hardware support. This also gives me extra "codes" in every subsection of my reader (I use a Carly), but I think these are harmless. i will say that their lowering module works very well, without any codes or side-effects, but... I should have stayed with that.
Old Oct 20, 2024 | 06:07 AM
Blackrain's Avatar
2016 S550, e39 M5
OP, thanks for the honest feedback. I was looking at adding their tune to their well received lowering mod, but you just saved me from buying another $$ paperweight. Regards.
Old May 5, 2026 | 06:39 AM
Z06Life's Avatar
2020 S560 4matic. 2017 Z06 convertible.
With a 100hp gain it should be massively noticed. If you can't tell, you got junk. Even a 15hp gain can be noticed.
Old Jun 11, 2026 | 07:30 PM
Markis Shagal's Avatar
GT63s , GLC 63 s , s550
i have this on my S class and it works great !
Old Yesterday | 11:15 AM
JohnLane's Avatar
222 S-65
Peter gave my car his tune. Performs as promised in lower ambient temperatures (traction limited!). It is summertime in here in the valley of the sun. When ambient temps are over 80 degrees boost gets pulled. Safety first! Water/Methanol injection is and has been ordered for months now. Peter tells me it makes a huge improvement due to lower intake air temperatures.
Old Yesterday | 01:23 PM
Z06Life's Avatar
I hope your meth kit has a safety system. Things go bad fast if you run dry. I personally prefer to run E85 for additional cooling.
