e63 coilover conversion awd (hydraulic delete)
Old Apr 21, 2024 | 08:24 PM
pdx63s's Avatar
e63s w212
I am considering converting the air suspension on my 2014 E63 AMG S awd airmatic to a coil spring setup. I'm looking at the Arnott Air Spring to Coil Spring Conversion Kit (C-3550) that's for the e/cls platform after lots of research it appears to be one of the best ones for the conversion. is there anything to be prepared for before doing so? Im not worried about the electronics i can get them codded out. would this conversion kit fit the e63 without any other modifications or parts? the whole idea is to get rid of the hydraulic and almost worn out oem suspension car is at 90k. is there any big differences between the cls and e platfrom or just that it sits a couple mm lower? any help or insight would be really appreciated Thank you all.
https://arnott.mycarparts.com/items/C-3550 installation manual w pics: https://illumaware-digital-assets.s3...0c6b681a73d73f
Old Apr 22, 2024 | 09:32 AM
berti_00's Avatar
2016 Cls63s AMG
to bad they are not coils
Old Apr 22, 2024 | 10:55 PM
pdx63s's Avatar
e63s w212
quick update i heard back from arnott and they confirmed it fits hopefully everything goes well
Old Apr 22, 2024 | 11:53 PM
pdx63s's Avatar
e63s w212
i decided not to go with them since they were not adjustable and cba to do custom springs on them, i went with scale conversion kit.
Old Apr 26, 2024 | 12:11 AM
Rehabguy's Avatar
E63S
Some retailers list KW V1 and V3 as compatible with w212 4matic. Some others would list this kit as "except AIRMATIC". Then there are the BC Racing BR coilovers that are listed in some websites as "W212 RWD only" and others list as for "non-AMG W212s". There is also this Asian company called CEIKA that produces a kit supposedly for W212 AMG 09 and up (with many customizable options). None of them make any mention of what happens with the electronics.
Some time ago, I had found a company called Yellowspeed that listed a set of coilvers that supposedly would work in the AWD W212 E63S... just checked... no longer listed.
It really sorta sucks there isn't much aftermarket support for the facelift models while there seems to be so much more for the W211s.
Good luck trying to get this done and pls report back should you be successful at it.
Old Jun 17, 2024 | 12:40 AM
pdx63s's Avatar
e63s w212
completed the conversion
update: everything went smooth with the swap, suspension feels almost the same however no more hydraulic future issues and expensive oem parts. i attached some pics of the result theyre height adjustable good quality materials would reccomend 100% if your shocks ever go out on a 212 or cls. however in the future i would look at kw's and check if they fit since they have crazy reviews but no issues with the scale brand.
Old Jun 17, 2024 | 09:03 AM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Share more details please
Did you have any option for spring choices? how much adjustability do you get?
How easy is it to change dampening/rebound once installed?
Rebuildable? Can you use springs from various manufacturers? i.e. are they a standard diameter?
I had KW V3s on my Subaru STi and absolutely loved them. Once they were dialed they were amazing. Ride was better than stock on the road, and when pushed the car was always settled (along with sway bars and a proper alignment). Would gladly run KW V3 on the E63s if that was an option if replacing the OEM suspension. Not too concerned about the lack of integration with the electronics as I would just dial the suspension in and leave it alone. The OEM suspension is way too soft in 'comfort', and I would just leave it somewhere between a 'sport and sport+' setting. The front end needs a ton more support as it 'collapses' under hard braking.
Old Jun 17, 2024 | 11:01 AM
PeterUbers's Avatar
nice work and thanks for this contribution
what did you do with the airmatic error message? Sorry if you already mentioned
Old Jun 17, 2024 | 07:23 PM
Ultrakla$$ic's Avatar
Benz w221 s550
I would like to know this as well
Old Jun 17, 2024 | 10:05 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Just so you know the E has air suspension and not hydraulic. The S, CL, SL's had hydraulic. Don't miss those days.
Old Jun 26, 2024 | 06:31 PM
Paulie Junior's Avatar
2013 c399
whats your experience with this? i know they have a kit that over rides the adjustable shocks, but what happpnes when you remove the airbags? did you fulkly remove the compressors aswell?
Old Sep 30, 2024 | 01:49 PM
Cla1111's Avatar
2015 E63 S
I am also looking at coilovers. I have contacted Yellowspeed and BC and they both have kits that are compatible with my 2015 E63s AWD:
Yellowspeed part number for E63 AWD is YS01-MB-DPS099.
BC Racing has a kit (front and rear), part number is: J-23-BR, but since they sell individual spare parts for their kits they can sell just the front for $362 each. I did not ask for the rear because I want to keep the airmatic.
Old Oct 1, 2024 | 12:28 PM
Rehabguy's Avatar
E63S
Good to know! Thanks!
Old Oct 4, 2024 | 11:44 AM
JBP.'s Avatar
Would these be sedan only? Or Wagon compatible?
Old Oct 4, 2024 | 11:56 AM
Cla1111's Avatar
2015 E63 S
They are for sedan only. I did not ask for the wagon.
Old Feb 28, 2025 | 12:43 PM
Mikeye63s's Avatar
Q
Do you have a link for this? My air suspension seems to be in the process of giving out and need a solution asap. Can you tell me what brand this is and possibly a purchase link please?
All the best,
Mike
Old Mar 3, 2025 | 07:26 AM
NH_E63's Avatar
2015 E63 AMG S
The OP mentioned scale conversion kit, found this, think it's the one as it looks similar. https://scalesuspension.com/product/...16-innovative/
Old Mar 4, 2025 | 08:06 PM
berti_00's Avatar
2016 Cls63s AMG
Would these fit a cls63s
Old Jan 29, 2026 | 10:36 AM
rocco46's Avatar
E63 AMG S
I don't think this question ever got answered and I was also curious. Here is a link to the Scale coilover conversion - I've never heard of these until I saw the post above.
https://scalecoilover.com/products/m...45151427920053
It looks like Scale sells an EDC delete kit so you won't run into airmatic error messages. Link below:
https://scalecoilover.com/products/e...45402790920373
I'm very curious on the ride quality compared to the OEM setup. I ran the H&R springs on my 2014 E63S last year and they were fine, but they lowered the car way more than I expected (about 1 3/4 inches). I was looking for about a 1" drop and I like having the adjustability so I'm swaying more towards the KW HAS kit.
Old Jan 30, 2026 | 10:57 PM
Rehabguy's Avatar
E63S
KW HAS def. the way to go. I had it in my car and the front was great... the adjustable links that come with the kit are absolute garbage. Buy metal links on eBay.
Old Jan 31, 2026 | 12:55 PM
RVAE34's Avatar
S212/M5T/Z31/240Z/3rd gen Tacoma
I agree on the HAS kit. That's what I have on my wagon. Tried H&R springs with links first and hated the feel up front. I also just replaced the shocks and struts on my car at 100k milest and can tell you it made a massive difference! I find that the car rides the best in sport mode when lowered. C or S+ are too extreme either way. My rear had become a tad too bouncy. New shocks fixed that right up. The only benefit of the KW links over the metal ones is that they have ball joint sockets on both sides. So you have more fine tuning ability where you can connect every half turn instead of a full turn.
I went down a rabbit hole of trying to create my own coilover setup for the rear of the BMW E39 touring and was never really happy with it. I worked with Fortune Auto and tried several shock valvings and spring rates. I would only trust a tried and true kit from a reputable company. Wagons are incredibly hard to get right in the rear. Especially with a divorced spring/shock where you adjust the height of both the spring perch and shock length independently of one another. In the end, I felt that a wagon needs a much heavier spring rate with a softer damper. It seems most kits do the opposite. Odd to think increasing spring rates improve ride quality but in my experience, that was absolutely the case.
My car on the KW HAS
