Oil pump solenoid - disconnect?
Old Jun 8, 2024 | 03:45 PM
skiracer's Avatar
E400 wagon
I ran across this modification, and it sure seems to make a lot of sense for M157 engines - has anyone here heard of this or done it to their G?
Old Jun 8, 2024 | 04:35 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
We did this to our E63 as part of the build.... Suggested by our shop.
Old Jun 8, 2024 | 06:10 PM
xxaarraa's Avatar
Multiple
@skiracer welcome to the community. Just joined and already looking at mods, I love it!!!! We need more guys like you.
I am intrigued and willing to try it. I looked in engine bay and in W463 M157, I can't see or locate the solenoid at the 7'o clock position from crank from above or from the side. At a minimum, front skid plate needs to come off or radiator fan needs to come out.
If you have success locating and getting access to connector, post up here.
Old Jun 10, 2024 | 01:27 PM
xxaarraa's Avatar
Multiple
Good video regarding solenoid delete...
Old Jul 12, 2025 | 10:33 AM
xxaarraa's Avatar
Multiple
OK @skiracer I did this yesterday. Solenoid is easily accessible at the front of the motor, you have to do it by feel as its not visible. Taped it up and drove about 800 miles since then.
I am a fan. Car seems much smoother. Transmission seems to hold gears in comfort just a bit longer which is very nice. No idea about long term effects (so much literature on this subject on youtube), but I definitely subscribe to the pleasant butt dyno effects of this simple mod. I plan to keep getting my oil tested through blackstone so I will keep an eye on any change.
Old Jul 12, 2025 | 12:15 PM
W205C43PFL's Avatar
Old Jul 13, 2025 | 09:12 AM
bejoy's Avatar
2015 ml63 amg (w166/m157) | 2015 g550 (w463/m273)
1500 miles ago, i did oil pump solenoid disconnect on the m157 ml63 and, seems to run better than ever since.
is there similar option for m273 g550?
Old Jul 13, 2025 | 10:04 AM
W205C43PFL's Avatar
Thanks for the feedback.
Old Jul 24, 2025 | 12:49 PM
skiracer's Avatar
E400 wagon
Thanks for trying this mod and for the positive results and feedback. I'm away from home for the summer and will get to this mod myself upon my return in late September. I installed Ohlins shocks and upgraded the ECU just before I left in June but haven't had any time to really drive it yet. This gives me something else to look forward to.
Happy driving - cheers!
Jim
Old Jul 24, 2025 | 05:29 PM
bejoy's Avatar
does anyone know similar oil pump solenoid mod for m273 engines, like in 2015 g550?
Old Jul 24, 2025 | 05:39 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
M273 does not have that variable volume oil pump.
Old Jul 24, 2025 | 06:46 PM
bejoy's Avatar
thank you for answering what is apparently a dumb question.
Old Jun 21, 2026 | 09:51 AM
W211Johnny's Avatar
w211 e55 w220 s55
M157 oil pump solenoid mod
I recently disconnected the oil pump solenoid on my 2012 e63 the car seems to run significantly better but I have gotten a ad a quart of oil like three times and I pull over wait 30 minutes to check the oil and the oil level seems to be fine. I’m just curious if anybody else has ran into this after the oil pump solenoid modification/disconnecting in M157 car
Old Jun 21, 2026 | 10:55 AM
xxaarraa's Avatar
Multiple
happened to me once when I idled the car for an extended period of time and was running 0-40. Similar to you, my oil level was never low but car thought so once.
I switched to 5-40 and has never happened again.
My guess is that the higher flow at idle and thinner oil may have thrown the oil level sensor.
Old Jun 21, 2026 | 03:19 PM
W205C43PFL's Avatar
Some also tried 5W-50 but if want to stick with 5W-40, I recommend motul or pennzoil.
