Car will not rev passed 3000RPM code P010C38 MAF short to ground help.
Hi All
I have a friends E Class Cab A207 I am trying to help him with an issue on that he has low power and the car will not rev passed 3000 rpm so feels sluggish.
I have used three different diagnostic tools, Launch, iCarsoft and Maxicom and they all provide the same errors which is good, these are:
Autel Maxicom 808 errors: P246364 - Soot content of the DPF is not OK, there is an implausible signal.
P246385 - Soot content of the DPF is not OK, there is a signal above the permissible limit value.
P010C38 - MAF sensor 2 has a short circuit to ground. There is an incorrect signal frequency.
Launch errors: Same numbers as above
iCarsoft:
Same numbers but on the MAF it states sensor B instead of sensor 2 (so still seems correct)
My thoughts are that the DPF and MAF faults are unrelated and merely coincidental. The car has been taken for a long drive with high revs to try and clean the DPF.
In regards to the MAF can someone tell me which MAF sensor looking at the engine is sensor 2 or B (i.e. left or right)
I have tried to clean the MAF with some contact cleaner but no joy, which you think that a new MAF should fox the issue P010C38 ?
If I clear the faults they come straight back.
Do you think you can read your sensor using a scanner?
It seems it is missing power. Likely a regulated 5V or internally controlled from a 12V input AND a clean GND as always.
That could be shorted out by another sensor sharing power.
So double-check that now or skip fwd... a new MAF does sound appealing.
Happy troubleshooting.
Not sure what year, but when I had MAF sensors I'd use brake cleaner on them. Mainly I'm posting because I remember how expensive the MAF was. The dealer wanted like $500 and elsewhere was like $200? Then I saw the same sensor at a friends VW shop for $20. So I bought one just to see and it was in fact the same MFing sensor and worked fine. Same mfg too, which I forget now. So I kept it in the trunk as a spare, and troubleshooting tool. Fyi.
PS; nice lookin car you got there A1. Scotland ay? Ever heard of Rose Castle? 1/4 of my blood comes from that place.
