Climate Control Unit location and AC Control Valve replacement question
Old 06-27-2024, 02:00 PM
m4gnum's Avatar
C300 W205
Hello. I am having AC issues in my 2015 Mercedes C300 (with codes M014 and 919), which is only blowing warm air. I am trying to find the problem for a while now.
A member of this forum pointed out a possible ground circuit issue since most of the faulty sensors share same ground:
- B10/8 (Rear Center Air Vent Outlet Temperature Sensor) is showing -57 F
- B10/6 (Evaporator Temperature Sensor) is showing 108 F
- Scanner is reading a fault code B1113-15 (Temperature Sensor 'Right Footwell Vent Has A Malfunction. There Is A Short Circuit To Positive Or An Open Circuit)
- Scanner is reading a fault code B19A400: LIN bus 2 of the air conditioning system has a malfunction.
Could you advice on how to locate and test that circuit?
Also, there might be an issue with AC control valve. Is it replaceable in a W205 or it requires a new compressor?
Does anyone know the part number?
Thank you
Old 06-27-2024, 11:54 PM
CaliBenzDriver's Avatar
Received 3,357 Likes on 2,235 Posts
MY'14 W212 M276 3.5NA @55kMi
Thank you
This is a great survey... you may not need a compressir or duty control valve if not proven guilty.
Plenty of other qualified reason for AAC module to veto service - Don't jump to conclude you need big ticket job: new evap coil
Your "evap 108C" is just saying system is at rest.
Rear vent -57c sounds like your scanner has limited support (showing random data!!) - FEEL FREE TO IGNORE THIS!
What has me concerned is the LIN Fault. I think this is upsetting your AAC module.
Diagram shows multiple LIN buses
Where does B2 command ???
If you want to gently back-probe the AAC fragile connector you will have access to everything in one single place.
Grab the opportunity to clean the painted GND near L+R footwell area.
Passenger side sensor got torned up in the course of servicing cabin filter. Have a looksee.
m4gnum (06-28-2024)
Old 06-28-2024, 12:15 AM
m4gnum's Avatar
C300 W205
Thank you for taking a look into this and giving a new light.
I am throwing up my hands on this for weeks.
Do you mean cleaning the ground in the AC control unit?
If you don't mind me taking a bit more of your time, I have a separate post in regards to the AC issue where I get into more data details.
https://mbworld.org/forums/mercedes-...ml#post8992329
Old 06-28-2024, 12:21 AM
Can you pls SUMMARIZE CURRENT STATUS ?
I'll help you untangle your issues.
m4gnum (06-28-2024)
Old 06-28-2024, 01:13 AM
m4gnum's Avatar
C300 W205
I'll try to consolidate and summarize all my other posts.
Vehicle Information 2015 Mercedes C300 W205
Mileage: <50,000 miles
Symptoms and main observation:
  • AC blowing warm air, no cold air.
  • Heating works fine; air gets warmer when temperature is turned up.
  • AC compressor starts spinning when turned on, stops when turned off.
  • Fan behind the radiator engages.
  • Low side pressure is high (105 PSI), high side pressure is low (110 PSI)
  • Both low and high stay pretty much the same with AC on and AC off
Most recent Launch scanner results at 2PM and at 10PM:
Additional diagnostic observation:
  • Compressor Clutch (A9/7y2): OPEN with AC off, CLOSED with AC on.
  • Coolant Circulation Pump (M13/5): Stays off with AC on and off (can be manually activated with no temperature change).
  • Rear Center Air Vent Sensor (B10/8): Constant -58°F, does not change.
  • Refrigerant Pressure (B12): 9.80 - 10.50 bar.
  • Evaporator Temperature Sensor (B10/6): 118-119°F.
  • Governor Power Consumption: Jumps from 0A to 24A with AC on, temperature increases from 165°F to 190°F.
  • Blower Motor RPM: Jumps from 0 RPM to 4540 RPM with AC ON.
  • Actuator Motor Positions: Some show 0 or -10000, indicating faults or misreads.
  • Coolant Temperature Sensor (B11/4): ~190°F.
  • EVAP System Vapor Pressure: -58.75 Pa.
  • Power Request to Component A9 (Refrigerant Compressor): high demand (98-100%) even at lowest setting, no refrigerant pressure increase.
  • Most of the faulty sensors share same ground
Error Codes:
  • B19A400: LIN bus 2 of the AC system malfunction. (did not show during automatic test but came up when I tested AC system manually)
  • P0597-00: Coolant thermostat electrical fault (cleared but occurred previously).
  • B1113-15: Right Footwell Vent Sensor malfunction (cleared but occurred previously).
Other most likely unrelated codes:
  • PO6DA00: Oil pump valve electrical fault.
  • U014787: Communication with "Head unit" malfunction.
  • U013200: Communication with "Suspension" malfunction.
  • C10C800: Warning from "Collision Prevention Assist".
SnapOn Scanner test a few weeks ago in cooler conditions, for comparison:
  • B10/6 (Evaporator Temp): 104.7°F.
  • B14 (Outside Temp): 89.5°F.
  • Outside Temperature: 83°F.
  • Interior Temp Sensor (N70b1): 98.4°F.
  • N70b1 Internal Fan: Running.
  • B10/35 (Left Footwell Vent Air Outlet Temp): 102.0°F.
  • B10/36 (Right Footwell Vent Air Outlet Temp): 103.1°F.
  • B10/31 (Left Side Air Vent Air Outlet Temp): 103.1°F.
  • B10/32 (Right Side Air Vent Air Outlet Temp): 104.0°F.
  • Coolant Temperature: 167°F.
Previous Voltage Issues, which might be related:
  • Battery load tested as good but dashboard showed "Stop Vehicle, Shift to P, Leave engine running" message.
  • Voltage regulator replaced, some codes cleared.
  • Battery replaced, dashboard message cleared.
  • Coolant refilled with G13 instead of G40 not too long before AC issue occured, not sure if this could be related
  • I also purchased a new thermostat due to P0597-00 code but I have not replaced it yet as the code cleared
  • I am including all fault codes which showed before replacing the battery and voltage regulator, along with clearing the codes, in spoiler box below
Spoiler
Old 06-28-2024, 02:57 AM
Now excellent survey, thank you
Every necessary condition is present for compressor to pump. Right now it spins without building a head pressure.
Your compressor governor is jammed. Replace it
m4gnum (06-28-2024)
Old 06-28-2024, 08:22 AM
m4gnum's Avatar
C300 W205
Thank you so much! I really appreciate it!!
Just want to clarify, by governor you mean the AC control valve (solenoid), correct?
Do you know if it's replaceable or if I need to replace the whole compressor?
Upon doing some reading, I found that a faulty AC pressure switch could also be causing the same problem. Is that a possibility in my case or it's definitely a mechanical jam?
Old 06-28-2024, 01:32 PM
Your survey shows the compressor is running and pressures remain equalized: no effective pumping!
Yes, it's the compressor pressure solenoid at the rear (not clutch solenoid at the front). It controls the compressor tilt plate with a pulsed voltage.
Your are reporting your B12 pressure sensor showing 10Bar. This tells us the sensor is working and the charge level is fine. However if you can get a good quality replacement sensor, I would replace it preventively since you will have the circuit depressurized anyway.
The cheap service ports Schrader valves are classic leakers once disturbed... replace them too.
Old 06-28-2024, 02:37 PM
m4gnum's Avatar
C300 W205
Once again, BIG THANK YOU!
I will have that replaced.
Just having a hard time finding the right part number for the compressor valve (the compressor # is most likely A0008303002) and the schrader port valve core (the ones available online do not show fitment with 2015 model). I sent a message to the manufacturers.
I also purchased an expansion valve (OEM from Four Seasons) since I thought that it might be faulty. Would you replace it or leave the genuine one in, since it not causing any problems?
Old 06-29-2024, 05:21 AM
You know that's a good question.
If you have a good quality part on hand and the refrigerant is going to be evacuated ok. Right now its guaranteed not to be causing compressor upset.
Quick Reply: Climate Control Unit location and AC Control Valve replacement question
