Popping noise on Door Hinge
Old 06-28-2024, 06:41 AM
nys29's Avatar
2015 S63 Coupe
There is a popping noise coming from the Drivers-side door hinge whenever I open or close the door on my 2015 S63 Coupe. Looking to see if there is a fix to this.
File Type: mov
Old 06-28-2024, 10:33 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
may not fix it but put some oil all on and around the joint. Does the door close with good gaps and fit exactly into place?
Old 07-04-2024, 03:34 AM
nys29's Avatar
2015 S63 Coupe
Yes, the door does close perfectly with perfect gaps too. It's just the noise from the door hinge.
Old 07-14-2024, 09:39 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
As mentioned, a little lube on the hinge will probably fix it.
Old 07-14-2024, 09:53 AM
TimC300's Avatar
I like to spray a little white lithium grease in the door hinges as part of my yearly preventative maintenance program.
Quick Reply: Popping noise on Door Hinge
