Just dropped the pan on my transmission because my transmission would slip after 30ish seconds being in gear into "neutral" while the display shows in gear, the fluid was brown and the bottom of the pan was grey, figured the clutch on my torque converter was probably gone but was also met with a bunch of small metal shavings, threw up a huge red flag for me, what should I do?
conventional auto gearboxes never slip in to neutral - they don't work like that
they work by the fluid applying pressure on and off to many wet multi-plate clutch packs - depending which is in use, it gives the various gear ratios
the electro-hydraulic solenoids that do the work to get the various clutch packs operating can fail or block.... the tiny amount of swarf in your box is "normal" on these hideous joke boxes Merc peddle. you need someone to tell you whats going on by looking at the fill rate adaptions of the solenoids... highly likely a full rebuild will be needed, if its not a failed or blocked solenoid
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, and 2017 Mustang GT, and just got a 2023 300C
My S600 5 speed automatic transmission failed at 75K miles. Same story. Metal filings in pan. No pressure after warm-up. Replaced with a Mercedes remanufactured transmission on the extended warranty after their insurance adjuster visited the car and actually examined the codes. Approved the claim for transmission immediately. Also asked for a replacement torque converter and TCU; and extended warranty company denied the claim. I paid for it anyway since I love the car and wanted it properly repaired. Total bill was $9800 and I paid $4K; extended warranty paid $5800. You may be able to do it cheaper with a used box. Depends on how long you plan to keep the car.
Yikes. I'm down to 3 months on my warranty. I'd have a hard decision if I got a $9800 bill next year.
It's toast bro. Drop it there in your garage, swap out the TCU and bolt up the used box. They don't weigh anything. I used to bench press Chevy TH350's into Camaros.
I would never buy a used Mercedes especially a V12 without an extended warranty. I am just sorry I didn't buy more than 4 years and 50K more miles from purchase date. On the other hand, I love this car. It is a great platform. I don't mind the extra costs of maintenance. I can't really afford a new one, and if all goes well, I will buy a 2019 S class Coupe with a V12 (and an extended warranty!!) in the next year or so. Not sure I can afford that either, but it is on my bucket list and I am 73 years old.
if you have a S600 these eat gearboxes every-time anyone notices the car was fitted with a throttle pedal - 30k mile rebuild is common - they make the 7G look like a good choice
They live a LOT longer when fluid gets changed with regularity.
Five speed box in my 221 S-65 was a happy camper at 150,000 miles when I traded out of that car for my current steed.
I’m fond of doing a drain and fill every other engine oil change. Your 221 cars have a dipstick tube, drain plug in the box and in the torque converter. Easy peasy.
