Fault code
2013 ML350 Bluetec
Ummm
I'd start with checking the power supply at fuses 22,23,24, and 25.
Do you have a real question or would you care to explain what exactly the problem is? You might get a better reply...
yes, my mercedes 350ml w166 have problem to start the engine, it start at the second attempt and then shut down after appr 5-7 minutes.
i have removed the ad-blue 2 years ago.
picture number 2
Is the oxygen sensor error also active and on your car? 2nd picture?
