SL/R231: Correct oil for SL550?
Morning,
I want to make sure I take an extra quart with me as I go on a 2,000 mile road trip coming up soon. I know it's Mobile 1, but is it SAE OW-40, or 5-40? I see both are listed in the owners manual but I am not sure which to buy..
The car had the 30,000 mile service before I bought it from Mercedes about a year ago, and it is saying an A3 service is due in 19 days.... which will be when I get back from the trip..
2016 SL 550 with about 33,000 miles.
Thanks,
Barry
Thanks,
Barry
2020 GLC300 -2013 Sl550 - 1997 SL600
Both are correct,
It shouldn’t matter temporarily.
Just make sure the shop uses the latest SP grade Mobil 1 when you get the oil finally changed. There is still old stock floating around.
Mercedes M278 spec is 229.5
https://mbworld.org/forums/attachmen...spec_223_2.pdf
Latest list of approved motor oils from MB: (just be sure to give it some time to let the full list load on the webpage)
https://operatingfluids.mercedes-benz.com
Good Luck
Good Luck
Received 1,626 Likes
Check out this thread as well. Maybe you'll get through the whole thing before your trip. But the Thread Starter does a good summary in the first posting. I recommend going with 5W-40 and have actually switched to Pennzoil Platinum Euro 5W-40, API SP and MB 229.5 Approved.
Oil pump solenoids - MBWorld.org Forums
