Procedure on fuel filter recall
Does anyone know the procedure for the recall that was used about a year ago on something to do with the fuel line? Does the front valence get removed? My front looks like it was removed and then improperly put back.
thanks
C
thanks
C
I notice you have a 2021. There was fuel pump recall (NTSA: 23V-445). I don't see one for a fuel filter or fuel line. If I have to guess for the fuel pump the fuel tank need to be dropped. I don't think you can get it through the rear seat on some of the other vehicle I have done.
Had my 22 fuel pump recall done. For my GLE AMG 63S, they needed to remove the bumper, etc. and drop the tank. They had my car for 2 days. I think it takes 5 or 6 h of labor to do it. A big job for sure.
2017 Mercedes-Benz GLE AMG 63s
Check engine like a week after recall
About a week after I had the recall done I now have a check engine light and dtc's p2402, p2407, and p24c1
Looks to be unrelated, but wondering if anyone else had an issue after and whay that issue was?
Also, if not related to the recall, anyone have these codes and can share what repair fixed it?
P2407 - EVAP System Leak Detection Pump Sense Circuit Intermittent/erratic.
P24C1 - EVAP System Leak Detection Pump Switching Valve Performance/Stuck off has been detected.
I would check the Fuel cap and the Vapor Canister Purge Solenoid valve first.
