Turn on front sensors
Received 2,680 Likes
If you are talking about the ticking sound from the injectors then yes it is normal, I am unable to open that file for some reason, do you mind uploading to youtube and then linking it here?
Hmmm, is the vehicle bought new or you just bought it used, do you know and certain that it has front sensors? Most likely you know how the sensors look right? They are those circle indents. https://i.ebayimg.com/images/g/0DkAA...aN/s-l1200.jpg
Do you see these little bars with the Parktornic logo in the middle https://encrypted-tbn0.gstatic.com/i...23Ty1eqYSTsw&s
They are either incorrectly wired or disabled in the car coding. Should automatically turn on when going below a certain speed and show the bars light up as you approach an obstacle.
You might also be missing the module entirely if the bumper was replaced.
C450/C45 2016
Engine noise
Another question, is that a normal engine noise when the front engine cover is open?
https://we.tl/t-JIP7WQTllM
As for the parking sensor situation, you will need to connect a scanner and look for codes. If like the other forum member mentioned, the bumper was replaced, they might had indeed replaced it with one that has sensors but the car didn't originally came with sensors, you have rear sensors by chance? At least if you do have rear sensors, it might be real sensors in the front but still has a possibility of both front and rear bumpers replaced.
C450/C45 2016
i took it to a shop. apparently those sensor holes are closed and do not have any sensors connected to it. the car came originally with sensors as i believe but doesnt have that now sadly. and no i do not have any back sensors.
Sorry to hear that, I guess the sad news is the front bumper was indeed replaced. I wonder why the front bumper was replaced : ( other than if it was an accident.
